Adds a schedule to a snapshot copy policy
count- number of snapshot copies to maintain for this schedule # recommended optional properties -
prefix- prefix to use when creating snapshot copies at regular intervals # default property values if not specified in post, the following default property values are assigned: -
prefix- value ofschedulename# related ontap commands -
snapshot policy add-schedule# learn more -
doc /storage/snapshot-policies/{snapshot-policyuuid}/schedules](#docs-storage-storage_snapshot-policies_{snapshot-policyuuid}_schedules)
POST /storage/snapshot-policies/{snapshot-policy.uuid}/schedules
Adds a schedule to a Snapshot copy policy.
Required properties
schedule.uuidorschedule.name- Schedule at which Snapshot copies are captured on the volume. -
count- Number of Snapshot copies to maintain for this schedule.
Recommended optional properties
prefix- Prefix to use when creating Snapshot copies at regular intervals.
Default property values
If not specified in POST, the following default property values are assigned:
prefix- Value ofschedule.name
Related ONTAP commands
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
snapshot-policy.uuid |
string |
path |
True |
Snapshot copy policy UUID |
Request Body
| Name | Type | Description |
_links |
count |
integer |
The number of Snapshot copies to maintain for this schedule. |
prefix |
string |
The prefix to use while creating Snapshot copies at regular intervals. |
schedule |
snapmirror_label |
string |
Label for SnapMirror operations |
snapshot_policy |
This is a reference to the Snapshot copy policy. |
Example request
"href": "/api/resourcelink"
"prefix": "string",
"schedule": {
"name": "weekly",
"snapmirror_label": "string",
"snapshot_policy": {
"name": "default",
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1638407 |
When adding schedule to a Snapshot copy policy, the count for that schedule must be specified. |
1638410 |
Specified schedule already exists in snapshot policy. |
1638413 |
Schedule not found. |
1638451 |
This operation would result in total Snapshot copy count for the policy to exceed maximum supported count. |
1638508 |
Another schedule has the same prefix within this policy. |
1638528 |
This operation is not supported in a mixed-version cluster. |
1638531 |
This operation is not supported because specified policy is owned by the cluster admin. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
schedule
_links |
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
snapshot_policy
_links |
name |
string |
uuid |
string |
snapshot_policy_schedule
The Snapshot copy policy schedule object is associated with a Snapshot copy policy and it defines the interval at which Snapshot copies are created and deleted.
_links |
count |
integer |
prefix |
string |
schedule |
snapmirror_label |
string |
snapshot_policy |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
