Create a configuration backup
POST /support/configuration-backup/backups
Creates a configuration backup. The required backup file name must end with .7z extension.
Required properties
node.uuidornode.name- The node UUID or node name on which the configuration backup will be created. -
name- The backup file name
Related ONTAP commands
system configuration backup create
Learn more
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202. |
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
Request Body
| Name | Type | Description |
auto |
boolean |
Indicates if the backup was created automatically. |
backup_nodes |
array[backup_node] |
The list of nodes included in the backup. |
download_link |
string |
The link to download the backup file. |
name |
string |
The backup name. |
node |
The node that owns the configuration backup. |
size |
integer |
The size of the backup in bytes. |
time |
string |
The backup creation time. |
type |
string |
The backup type. |
version |
string |
The software version. |
Example request
"backup_nodes": [
"name": "string"
"download_link": "https://10.224.65.198/backups/backup_file.7z",
"name": "backup_file.7z",
"node": {
"href": "/api/resourcelink"
"name": "node1",
"size": 4787563,
"time": "2019-02-04 13:33:48 -0500",
"type": "string",
"version": "9.7.0"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5963818 |
Failed to queue private job. |
5963819 |
Failed to queue cluster job. |
5963871 |
Requested backup name is missing .7z suffix. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
backup_node
The node name in the backup.
name |
string |
href |
string |
_links
self |
node
_links |
name |
string |
uuid |
string |
configuration_backup_file
The configuration backup file.
auto |
boolean |
backup_nodes |
download_link |
string |
name |
string |
The backup name. |
node |
size |
integer |
time |
string |
type |
string |
The backup type. |
version |
string |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
