REST API reference
Security endpoint overview
Overview
This API returns an object 'onboard_key_manager_configurable_status' which details whether the Onboard Key Manager can be configured on the cluster or not.
Retrieving information about the security configured on the cluster
The following example shows how to retrieve the key manager configiration of the cluster.
# The API:
GET /api/security:
# The call:
curl -X GET 'https://<mgmt-ip>/api/security?fields=*' -H 'accept: application/hal+json'
# The response:
  "onboard_key_manager_configurable_status": {
    "supported": "false",
    "message": "Onboard Key Manager cannot be configured on the cluster. There are no self-encrypting disks in the cluster, and the following nodes do not support volume granular encryption: ntap-vsim2.",
    "code": 65537300
