Support ems filters endpoint overview
Overview
Manages the list of available filters. A filter is a named collection of rules that enable the system to identify events that require additional handling. A filter is linked with a destination to which the system sends specific events.
When EMS processes an event, each filter is evaluated for a match. More than one filter can handle a single event.
Filter rule position
A filter's rules are evaluated sequentially, according to their position index. When a rule is added or modified, the position can be set to customize the filter's logic. If no position is specified, a new rule is appended to the end of the list.
Filter rule types
A filter rule can be one of two types: 'include' or 'exclude'. If an event matches the criteria of the rule, the type dictates whether it should be forwarded to the destination or ignored.
Filter rule matching criteria
A valid filter rule must contain at least one set of criteria.
Name pattern
A name pattern is matched against an event's name. Multiple characters can be matched using the wildcard character '*'.
Severity
The severity pattern is matched against an event's severity. Multiple severities can be specified in a comma separated list. A single wildcard '*' will match all severities. Valid values are:
emergency
alert
error
notice
informational
debug
SNMP trap type
The SNMP trap type pattern is matched against an event's trap type. Multiple trap types can be specified in a comma separated list. A single wildcard '*' matches all trap types. Valid values are:
standard
built_in
severity_based
Retrieving a list of filters whose names contain a hyphen
# API
GET /api/support/ems/filters?name=*-*
# Response
200 OK
# JSON Body
"records": [
"name": "default-trap-events",
"href": "/api/support/ems/filters/default-trap-events"
"name": "important-events",
"href": "/api/support/ems/filters/important-events"
"name": "no-info-debug-events",
"href": "/api/support/ems/filters/no-info-debug-events"
"num_records": 3,
"href": "/api/support/ems/filters?name=*-*"
Creating a new filter using various matching criteria
# API
POST /api/support/ems/filters
# JSON Body
"name": "test-filter",
"rules": [
"index": 1,
"type": "include",
"message_criteria": {
"name_pattern": "LUN.*",
"severities": "alert,error",
"snmp_trap_types": "severity_based"
# Response
201 Created
