Delete a software package from the cluster
DELETE /cluster/software/packages/{version}
Introduced In: 9.6
Deletes a software package from the cluster. The delete operation fails if the package is currently installed.
Related ONTAP commands
cluster image package delete
Learn more
version  |
string  |
path  |
True  |
return_timeout  |
integer  |
query  |
False  |
Status: 202, Accepted
Status: Default
ONTAP error response codes
| Error codes | Description |
10551315  |
Package store is empty  |
10551322  |
Error in retrieving package cleanup status  |
10551323  |
Error in cleaning up package information on a node  |
10551324  |
Error in cleaning up package information on multiple nodes  |
10551325  |
Package does not exist on the system  |
10551326  |
Error in deleting older package cleanup tasks. Clean up images from the store and retry  |
10551346  |
Package delete failed since a validation is in progress  |
10551347  |
Package delete failed since an update is in progress  |
10551367  |
A package synchronization is in progress  |
10551388  |
Package delete operation timed out  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
