Delete an FC interface
DELETE /network/fc/interfaces/{uuid}
Introduced In: 9.6
Deletes an FC interface.
Related ONTAP commands
network interface delete
Learn more
Name | Type | In | Required | Description |
uuid |
string |
path |
True |
The unique identifier for the FC interface. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code | Description |
53280992 |
The FC interface could not be deleted because it is enabled. |
Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
