REST API reference
Delete iSCSI credentials
DELETE /protocols/san/iscsi/credentials/{svm.uuid}/{initiator}
Introduced In: 9.6
Deletes specified iSCSI credentials.
  • vserver iscsi security delete
svm.uuid
string
path
True
The unique identifier of an SVM.
initiator
string
path
True
The iSCSI initiator of the credentials object.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
2621462
An SVM with the specified UUID does not exist.
2621706
Both the SVM UUID and SVM name were supplied, but they do not refer to the same SVM.
2621707
No SVM was specified. Either svm.name or svm.uuid must be supplied.
5374148
The default security credential cannot be deleted for an SVM.
5374895
The iSCSI security credential does not exist on the specified SVM.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
