Delete an iSCSI service
DELETE /protocols/san/iscsi/services/{svm.uuid}
Introduced In: 9.6
Deletes an iSCSI service. An iSCSI service must be disabled before it can be deleted.
Related ONTAP commands
vserver iscsi delete
Learn more
svm.uuid |
string |
path |
True |
The unique identifier of the SVM for which to delete the iSCSI service. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621462 |
An SVM with the specified UUID does not exist. |
5373960 |
The iSCSI service is enabled. The iSCSI service must be disabled before it can be deleted. |
5374078 |
The SVM does not have an iSCSI service. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
