Delete a privilege tuple from the role
DELETE /security/roles/{owner.uuid}/{name}/privileges/{path}
Introduced In: 9.6
Deletes a privilege tuple (of REST URI and its access level) from the role.
Required parameters
owner.uuid- UUID of the SVM which houses this role. -
name- Name of the role to be updated. -
path- Constituent REST API path to be deleted from this role.
Related ONTAP commands
security login rest-role delete
owner.uuid |
string |
path |
True |
Role owner UUID |
name |
string |
path |
True |
Role name |
path |
string |
path |
True |
REST API path |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5636172 |
User accounts detected with this role assigned. Update or delete those accounts before deleting this role. |
5636173 |
This feature requires an effective cluster version of 9.6 or later. |
13434890 |
Vserver-ID failed for Vserver roles. |
13434893 |
The SVM does not exist. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
