Delete a role
DELETE /security/roles/{owner.uuid}/{name}
Introduced In: 9.6
Deletes the specified role.
Required parameters
name- Name of the role to be deleted. -
owner.uuid- UUID of the SVM housing the role.
Related ONTAP commands
security login rest-role delete
owner.uuid  |
string  |
path  |
True  |
Role owner UUID  |
name  |
string  |
path  |
True  |
Role name to be deleted.  |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5636172  |
User accounts detected with this role assigned. Update or delete those accounts before deleting this role.  |
5636173  |
Features require an effective cluster version of 9.6 or later.  |
13434890  |
Vserver-ID failed for Vserver roles.  |
13434893  |
The SVM does not exist.  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
