Delete a FlexCache volume
DELETE /storage/flexcache/flexcaches/{uuid}
Introduced In: 9.6
Deletes a FlexCache. If a FlexCache volume is online, it is offlined before deletion.
Related ONTAP commands
volume flexcache delete
Learn more
uuid  |
string  |
path  |
True  |
Unique identifier of the FlexCache.  |
return_timeout  |
integer  |
query  |
False  |
Status: 202, Accepted
| Name | Type | Description |
job  |
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
66846879  |
The specified volume UUID is not a FlexCache volume  |
66846731  |
Failed to delete the FlexCache volume  |
524546  |
Failed to delete the FlexCache volume because the FlexCache volume is not unmounted  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
job_link
_links  |
uuid  |
string  |
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
