Delete an NVMe namespace
DELETE /storage/namespaces/{uuid}
Introduced In: 9.6
Deletes an NVMe namespace.
Related ONTAP commands
vserver nvme namespace delete
Learn more
uuid  |
string  |
path  |
True  |
The unique identifier of the NVMe namespace to delete.  |
allow_delete_while_mapped  |
boolean  |
query  |
False  |
Allows deletion of a mapped NVMe namespace. A mapped NVMe namespace might be in use. Deleting a mapped namespace also deletes the namespace map and makes the data no longer available, possibly causing a disruption in the availability of data. This parameter should be used with caution.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
72090006  |
The specified namespace was not found.  |
72090007  |
72090016  |
The namespace's aggregate is offline. The aggregate must be online to modify or remove the namespace.  |
72090017  |
The namespace's volume is offline. The volume must be online to modify or remove the namespace.  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
