REST API reference
Delete a qtree
DELETE /storage/qtrees/{volume.uuid}/{id}
Introduced In: 9.6
Deletes a qtree.
  • qtree delete
volume.uuid
string
path
True
Volume UUID
id
string
path
True
Qtree ID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
918235
A volume with UUID was not found.
5242955
The UUID of the volume is required.
5242957
Failed to delete qtree with ID in volume and vserver.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
