Delete an existing file or directory
DELETE /storage/volumes/{volume.uuid}/files/{path}
Introduced In: 9.8
Deletes an existing file or directory. Query-based DELETE operations are not supported.
volume.uuid  |
string  |
path  |
True  |
Volume UUID  |
path  |
string  |
path  |
True  |
The relative path of a directory in the volume. The path field requires using "%2E" to represent "." and "%2F" to represent "/" for the path provided.  |
recurse  |
boolean  |
query  |
False  |
Delete an entire directory. The behaviour of this call is equivalent to rm -rf.
throttle-deletion  |
integer  |
query  |
False  |
The maximum number of directory delete operations per second. A valid throttle-deletion number is an interger from 10 to 100000.  |
return_timeout  |
integer  |
query  |
False  |
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
131074  |
No such file or directory.  |
131102  |
Read-only file system.  |
131138  |
Directory not empty.  |
918235  |
A volume with UUID {volume.uuid} was not found.  |
6488081  |
The {field} field is not supported for DELETE operations.  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
