Delete an event destination
DELETE /support/ems/destinations/{name}
Introduced In: 9.6
Deletes an event destination.
Related ONTAP commands
event notification destination delete -
event notification delete
name |
string |
path |
True |
Destination name |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983152 |
Default destinations cannot be modified or removed |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
