Retrieve application component Snapshot copies
GET /application/applications/{application.uuid}/components/{component.uuid}/snapshots
Introduced In: 9.6
Retrieves Snapshot copies of an application component.
This endpoint is only supported for Maxdata template applications.
Component Snapshot copies are essentially more granular application Snapshot copies. There is no difference beyond the scope of the operation.
Learn more
application.uuid |
string |
path |
True |
Application UUID |
component.uuid |
string |
path |
True |
Application Component UUID |
component.name |
string |
query |
False |
Filter by Application Component Name |
uuid |
string |
query |
False |
Filter by uuid |
name |
string |
query |
False |
Filter by name |
consistency_type |
string |
query |
False |
Filter by consistency_type |
comment |
string |
query |
False |
Filter by comment |
create_time |
string |
query |
False |
Filter by create_time |
is_partial |
string |
query |
False |
Filter by is_partial |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
"next": {
"href": "/api/resourcelink"
"records": [
"application": {
"name": "string",
"uuid": "string"
"comment": "string",
"component": {
"name": "string",
"uuid": "string"
"consistency_type": "string",
"create_time": "string",
"name": "string",
"svm": {
"name": "string",
"uuid": "string"
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
application
_links |
name |
string |
Application Name |
uuid |
string |
Application UUID. Valid in URL |
component
_links |
name |
string |
Component Name |
uuid |
string |
Component UUID |
svm
name |
string |
SVM Name |
uuid |
string |
SVM UUID |
application_component_snapshot
_links |
application |
comment |
string |
Comment. Valid in POST |
component |
consistency_type |
string |
Consistency Type. This is for categorization only. A Snapshot copy should not be set to application consistent unless the host application is quiesced for the Snapshot copy. Valid in POST |
create_time |
string |
Creation Time |
is_partial |
boolean |
A partial Snapshot copy means that not all volumes in an application component were included in the Snapshot copy. |
name |
string |
Snapshot copy name. Valid in POST |
svm |
uuid |
string |
Snapshot copy UUID. Valid in URL |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
