Retrieve capacity pool information
GET /cluster/licensing/capacity-pools/{serial_number}
Introduced In: 9.8
Retrieves information about the capacity pool.
Learn more
Related ONTAP commands
system license show-status -
system license show
serial_number |
string |
path |
True |
Serial number of the capacity pool license. |
nodes.used_size |
integer |
query |
False |
Filter by nodes.used_size |
nodes.node.name |
string |
query |
False |
Filter by nodes.node.name |
nodes.node.uuid |
string |
query |
False |
Filter by nodes.node.uuid |
license_manager.uuid |
string |
query |
False |
Filter by license_manager.uuid |
serial_number |
string |
query |
False |
Filter by serial_number |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
license_manager |
License manager instance where this capacity pool license in installed. |
nodes |
array[nodes] |
Nodes in the cluster associated with this capacity pool. |
serial_number |
string |
"href": "/api/resourcelink"
"license_manager": {
"uuid": "4ea7a442-86d1-11e0-ae1c-112233445566"
"nodes": [
"node": {
"name": "node1",
"used_size": 0
"serial_number": "390000100"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
license_manager
_links |
uuid |
string |
_links
self |
node_reference
_links |
name |
string |
uuid |
string |
nodes
Information on a node from the capacity licensing perspective.
node |
used_size |
integer |
Capacity, in bytes, that is currently used by the node. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
