Retrieve DR group information using the DR group ID
GET /cluster/metrocluster/dr-groups/{id}
Introduced In: 9.8
Retrieves the DR group information specified by the DR group id.
id  |
string  |
path  |
True  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
dr_pairs  |
array[dr_pair]  |
id  |
integer  |
DR Group ID  |
partner_cluster  |
Partner cluster information.  |
  "dr_pairs": [
      "node": {
        "name": "nodeA"
      "partner": {
        "name": "nodeB"
  "id": 0,
  "partner_cluster": {
        "href": "/api/resourcelink"
    "name": "cluster1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
node
Local node of the DR Group.
name  |
string  |
Name of the node.  |
partner
Partner node of the DR Group.
name  |
string  |
Name of the node.  |
dr_pair
node  |
Local node of the DR Group.  |
partner  |
Partner node of the DR Group.  |
href  |
string  |
_links
self  |
partner_cluster
_links  |
name  |
string  |
uuid  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
