REST API reference
Retrieve interconnect adapter information for nodes in MetroCluster
GET /cluster/metrocluster/interconnects
Introduced In: 9.8
Retrieves a list of interconnect adapter information for nodes in the MetroCluster.
  • metrocluster interconnect show
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
partner_type
string
query
False
Filter by partner_type
adapter
string
query
False
Filter by adapter
state
string
query
False
Filter by state
type
string
query
False
Filter by type
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of Records
records
array[metrocluster_interconnect]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "adapter": "string",
      "node": {
        "name": "node1",
      "partner_type": "string",
      "state": "string",
      "type": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
2425734
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
2427132
MetroCluster is not configured on this cluster.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
self
node
_links
_links
name
string
uuid
string
Data for a MetroCluster interconnect. REST: /api/cluster/metrocluster/interconnects
_links
self_link
adapter
string
Adapter
node
node
partner_type
string
Partner type
state
string
Adapter status
type
string
Adapter type
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
