Retrieve a node configuration in MetroCluster
GET /cluster/metrocluster/nodes/{node.uuid}
Introduced In: 9.8
Retrieves the node configuration in the MetroCluster.
Related ONTAP Commands
metrocluster node show
node.uuid |
string |
path |
True |
Node UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
cluster |
configuration_state |
string |
Configuration state of the node. |
dr_group_id |
integer |
DR Group ID. |
dr_mirroring_state |
string |
State of the DR mirroring configuration. |
node |
"href": "/api/resourcelink"
"cluster": {
"name": "cluster1",
"configuration_state": "string",
"dr_group_id": 0,
"dr_mirroring_state": "string",
"node": {
"name": "node1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
_links
self |
cluster
_links |
name |
string |
uuid |
string |
node
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
