REST API reference
Retrieve nodes in a cluster
GET /cluster/nodes
Introduced In: 9.6
Retrieves the nodes in the cluster.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • statistics.*
  • metric.*
  • system node show
service_processor.link_status
string
query
False
Filter by service_processor.link_status
service_processor.state
string
query
False
Filter by service_processor.state
service_processor.firmware_version
string
query
False
Filter by service_processor.firmware_version
service_processor.mac_address
string
query
False
Filter by service_processor.mac_address
service_processor.dhcp_enabled
boolean
query
False
Filter by service_processor.dhcp_enabled
service_processor.ipv4_interface.address
string
query
False
Filter by service_processor.ipv4_interface.address
service_processor.ipv4_interface.gateway
string
query
False
Filter by service_processor.ipv4_interface.gateway
service_processor.ipv4_interface.netmask
string
query
False
Filter by service_processor.ipv4_interface.netmask
service_processor.ipv6_interface.address
string
query
False
Filter by service_processor.ipv6_interface.address
service_processor.ipv6_interface.gateway
string
query
False
Filter by service_processor.ipv6_interface.gateway
service_processor.ipv6_interface.netmask
string
query
False
Filter by service_processor.ipv6_interface.netmask
serial_number
string
query
False
Filter by serial_number
statistics.timestamp
string
query
False
Filter by statistics.timestamp
  • Introduced in: 9.8
statistics.processor_utilization_base
integer
query
False
Filter by statistics.processor_utilization_base
statistics.processor_utilization_raw
integer
query
False
Filter by statistics.processor_utilization_raw
statistics.status
string
query
False
Filter by statistics.status
state
string
query
False
Filter by state
  • Introduced in: 9.7
vendor_serial_number
string
query
False
Filter by vendor_serial_number
location
string
query
False
Filter by location
vm.provider_type
string
query
False
Filter by vm.provider_type
uptime
integer
query
False
Filter by uptime
metrocluster.type
string
query
False
Filter by metrocluster.type
cluster_interfaces.name
string
query
False
Filter by cluster_interfaces.name
cluster_interfaces.uuid
string
query
False
Filter by cluster_interfaces.uuid
cluster_interfaces.ip.address
string
query
False
Filter by cluster_interfaces.ip.address
system_machine_type
string
query
False
Filter by system_machine_type
management_interfaces.name
string
query
False
Filter by management_interfaces.name
management_interfaces.uuid
string
query
False
Filter by management_interfaces.uuid
management_interfaces.ip.address
string
query
False
Filter by management_interfaces.ip.address
system_id
string
query
False
Filter by system_id
controller.frus.state
string
query
False
Filter by controller.frus.state
controller.frus.id
integer
query
False
Filter by controller.frus.id
controller.frus.type
string
query
False
Filter by controller.frus.type
controller.over_temperature
string
query
False
Filter by controller.over_temperature
controller.flash_cache.serial_number
string
query
False
Filter by controller.flash_cache.serial_number
controller.flash_cache.slot
string
query
False
Filter by controller.flash_cache.slot
controller.flash_cache.state
string
query
False
Filter by controller.flash_cache.state
controller.flash_cache.hardware_revision
string
query
False
Filter by controller.flash_cache.hardware_revision
controller.flash_cache.part_number
string
query
False
Filter by controller.flash_cache.part_number
controller.flash_cache.capacity
integer
query
False
Filter by controller.flash_cache.capacity
controller.flash_cache.firmware_version
string
query
False
Filter by controller.flash_cache.firmware_version
controller.flash_cache.model
string
query
False
Filter by controller.flash_cache.model
date
string
query
False
Filter by date
uuid
string
query
False
Filter by uuid
ha.partners.name
string
query
False
Filter by ha.partners.name
ha.partners.uuid
string
query
False
Filter by ha.partners.uuid
ha.ports.number
integer
query
False
Filter by ha.ports.number
ha.ports.state
string
query
False
Filter by ha.ports.state
ha.giveback.failure.code
integer
query
False
Filter by ha.giveback.failure.code
ha.giveback.failure.message
string
query
False
Filter by ha.giveback.failure.message
ha.giveback.state
string
query
False
Filter by ha.giveback.state
ha.enabled
boolean
query
False
Filter by ha.enabled
ha.takeover.failure.message
string
query
False
Filter by ha.takeover.failure.message
ha.takeover.failure.code
integer
query
False
Filter by ha.takeover.failure.code
ha.takeover.state
string
query
False
Filter by ha.takeover.state
ha.auto_giveback
boolean
query
False
Filter by ha.auto_giveback
metric.duration
string
query
False
Filter by metric.duration
metric.processor_utilization
integer
query
False
Filter by metric.processor_utilization
metric.timestamp
string
query
False
Filter by metric.timestamp
metric.status
string
query
False
Filter by metric.status
model
string
query
False
Filter by model
name
string
query
False
Filter by name
version.full
string
query
False
Filter by version.full
version.minor
integer
query
False
Filter by version.minor
version.major
integer
query
False
Filter by version.major
version.generation
integer
query
False
Filter by version.generation
membership
string
query
False
Filter by membership
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "cluster_interfaces": [
          "ip": {
            "address": "10.10.10.7"
          "name": "lif1",
      "controller": {
        "flash_cache": [
            "capacity": "1024000000000",
            "firmware_version": "NA05",
            "hardware_revision": "A1",
            "model": "X1970A",
            "part_number": "119-00207",
            "serial_number": "A22P5061550000187",
            "slot": "6-1",
            "state": "string"
        "frus": [
            "id": 0,
            "state": "string",
            "type": "string"
        "over_temperature": "string"
      "date": "2019-04-17T11:49:26-04:00",
      "ha": {
        "giveback": {
          "failure": {
            "code": "852126",
            "message": "Failed to initiate giveback. Run the \"storage failover show-giveback\" command for more information."
          "state": "failed"
        "partners": [
            "name": "node1",
        "ports": [
            "number": "0",
            "state": "active"
        "takeover": {
          "failure": {
            "code": "852130",
            "message": "Failed to initiate takeover. Run the \"storage failover show-takeover\" command for more information."
          "state": "failed"
      "location": "rack 2 row 5",
      "management_interfaces": [
          "ip": {
          "name": "lif1",
      "membership": "string",
      "metric": {
        "duration": "PT15S",
        "processor_utilization": "13",
        "status": "ok",
        "timestamp": "2017-01-25T11:20:13Z"
      "metrocluster": {
        "type": "string"
      "model": "FAS3070",
      "name": "node-01",
      "serial_number": "4048820-60-9",
      "service_processor": {
        "firmware_version": "string",
        "ipv4_interface": {
          "address": "10.10.10.7",
          "gateway": "10.1.1.1",
          "netmask": "24"
        "ipv6_interface": {
          "netmask": "24"
        "link_status": "string",
        "mac_address": "string",
        "state": "string"
      "state": "string",
      "statistics": {
        "processor_utilization_base": "12345123",
        "processor_utilization_raw": "13",
        "status": "ok",
      "system_id": "0537035403",
      "system_machine_type": "7Y56-CTOWW1",
      "uptime": "300536",
      "uuid": "4ea7a442-86d1-11e0-ae1c-123478563412",
      "vendor_serial_number": "791603000068",
      "version": {
        "full": "NetApp Release 9.4.0: Sun Nov 05 18:20:57 UTC 2017",
        "generation": "9",
        "major": "4",
        "minor": "0"
      "vm": {
        "provider_type": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
node_setup_ip
The IP configuration for cluster setup.
address
string
IPv4 or IPv6 address
cluster_interface
The cluster network IP address of the node to be added.
ip
IP information
address
string
cluster_interfaces
Network interface
_links
_links
ip
ip
IP information
name
string
The name of the interface.
uuid
string
The UUID that uniquely identifies the interface.
flash_cache
capacity
integer
Size in bytes
firmware_version
string
hardware_revision
string
model
string
part_number
string
serial_number
string
slot
string
state
string
frus
id
integer
state
string
type
string
controller
Controller information
flash_cache
array[flash_cache]
A list of Flash-Cache devices. Only returned when requested by name.
frus
array[frus]
List of FRUs on the node. Only returned when requested by name.
over_temperature
string
Specifies whether the hardware is currently operating outside of its recommended temperature range. The hardware shuts down if the temperature exceeds critical thresholds.
failure
Indicates the failure code and message.
code
integer
Message code
message
string
Detailed message based on the state.
giveback
Represents the state of the node that is giving storage back to its HA partner.
failure
failure
state
string
partners
_links
_links
name
string
uuid
string
ports
number
integer
HA port number
state
string
HA port state:
  • down - Logical HA link is down.
  • initialized - Logical HA link is initialized. The physical link is up, but the subnet manager hasn't started to configure the port.
  • armed - Logical HA link is armed. The physical link is up and the subnet manager started but did not yet complete configuring the port.
  • active - Logical HA link is active.
  • reserved - Logical HA link is active, but the physical link is down.
takeover
This represents the state of the node that is taking over storage from its HA partner.
failure
failure
state
string
ha
auto_giveback
boolean
Specifies whether giveback is automatically initiated when the node that owns the storage is ready.
enabled
boolean
Specifies whether or not storage failover is enabled.
giveback
giveback
partners
array[partners]
Nodes in this node's High Availability (HA) group.
ports
array[ports]
takeover
takeover
The management interface of the node to be added. The subnet mask is set based on the management interface of the cluster or the managment interfaces of other nodes.
Network interface
_links
_links
ip
ip
IP information
name
string
uuid
string
metric
CPU performance for the nodes.
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
integer
Average CPU Utilization for the node
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes do not have the latest data.
timestamp
string
The timestamp of the performance data.
metrocluster
Metrocluster
type
string
The Metrocluster configuration type
ipv4_interface
Object to setup an interface along with its default router.
address
string
gateway
string
The IPv4 or IPv6 address of the default router.
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length.
ipv6_interface
address
string
gateway
string
netmask
string
service_processor
dhcp_enabled
boolean
Set to "true" to use DHCP to configure an IPv4 interface.
firmware_version
string
The version of firmware installed.
ipv4_interface
ipv4_interface
ipv6_interface
ipv6_interface
link_status
string
mac_address
string
state
string
statistics
Raw CPU performance for the nodes.
integer
Base counter for CPU Utilization.
integer
Raw CPU Utilization for the node. This should be divided by the processor_utilization_base to calculate the percentage CPU utilization for the node.
status
string
timestamp
string
version
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes.
full
string
The full cluster version string.
generation
integer
The generation portion of the version.
major
integer
The major portion of the version.
minor
integer
The minor portion of the version.
vm
provider_type
string
Cloud provider where the VM is hosted.
records
Complete node information
_links
_links
cluster_interfaces
array[cluster_interfaces]
controller
controller
date
string
The current or "wall clock" time of the node in ISO-8601 date, time, and time zone format. The ISO-8601 date and time are localized based on the ONTAP cluster's timezone setting.
  • example: 2019-04-17T11:49:26-04:00
  • format: date-time
  • readOnly: 1
ha
ha
location
string
array[management_interfaces]
membership
string
Possible values:
  • available - A node is detected on the internal cluster network and can be added to the cluster. Nodes that have a membership of "available" are not returned when a GET request is called when the cluster exists. Provide a query on the "membership" property for available to scan for nodes on the cluster network. Nodes that have a membership of "available" are returned automatically before a cluster is created.
  • joining - Joining nodes are in the process of being added to the cluster. The node might be progressing through the steps to become a member or might have failed. The job to add the node or create the cluster provides details on the current progress of the node.
  • member - Nodes that are members have successfully joined the cluster.
metric
metric
metrocluster
metrocluster
Metrocluster
model
string
name
string
serial_number
string
service_processor
service_processor
state
string
State of the node:
  • up - Node is up and operational.
  • booting - Node is booting up.
  • down - Node has stopped or is dumping core.
  • taken_over - Node has been taken over by its HA partner and is not yet waiting for giveback.
  • waiting_for_giveback - Node has been taken over by its HA partner and is waiting for the HA partner to giveback disks.
  • degraded - Node has one or more critical services offline.
  • unknown - Node or its HA partner cannot be contacted and there is no information on the node's state.
statistics
statistics
system_id
string
system_machine_type
string
OEM system machine type.
uptime
integer
The total time, in seconds, that the node has been up.
uuid
string
string
OEM vendor serial number.
version
version
vm
vm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
