      Retrieve the software package information
GET /cluster/software/packages/{version}
Introduced In: 9.6
Retrieves the software package information.
Related ONTAP commands
cluster image package show-repository
Learn more
version  |
string  |
path  |
True  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
create_time  |
string  |
Indicates when this package was loaded  |
version  |
string  |
Version of this package
      "href": "/api/resourcelink"
  "create_time": "2019-02-04T19:00:00Z",
  "version": "ONTAP_X"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
