REST API reference
Retrieve cluster software packages
GET /cluster/software/packages
Introduced In: 9.6
Retrieves the software packages for a cluster.
  • cluster image package show-repository
version
string
query
False
Filter by version
  • Introduced in: 9.7
create_time
string
query
False
Filter by create_time
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 1
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
records
array[software_package]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "create_time": "2019-02-04T19:00:00Z",
      "version": "ONTAP_X"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
software_package
_links
_links
create_time
string
Indicates when this package was loaded
version
string
Version of this package
  • example: ONTAP_X
  • readOnly: 1
  • Introduced in: 9.6
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
