Retrieve the cluster software profile
GET /cluster/software
Introduced In: 9.6
Retrieves the software profile of a cluster.
Related ONTAP commands
cluster image show -
cluster image show-update-progress
Learn more
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
fields |
array[string] |
query |
False |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
action |
string |
User triggered action to apply to the install operation |
elapsed_duration |
integer |
Elapsed time during the upgrade or validation operation |
estimated_duration |
integer |
Estimated time remaining until completion of the upgrade or validation operation. |
metrocluster |
nodes |
array[software_node_reference] |
List of nodes and active versions. |
pending_version |
string |
Version being installed on the system.
state |
string |
Operational state of the upgrade |
status_details |
Display status details. |
update_details |
Display update progress details. |
validation_results |
List of validation warnings, errors, and advice. |
version |
string |
Version of ONTAP installed and currently active on the system. During PATCH, using the 'validate_only' parameter on the request executes pre-checks, but does not perform the full installation.
"href": "/api/resourcelink"
"action": "pause",
"elapsed_duration": "2140",
"estimated_duration": "5220",
"metrocluster": {
"clusters": [
"estimated_duration": "3480",
"name": "cluster_A",
"state": "in_progress"
"progress_details": {
"message": "Switchover in progress"
"progress_summary": {
"message": "MetroCluster updated successfully."
"nodes": [
"name": "node1",
"version": "ONTAP_X"
"pending_version": "ONTAP_X_1",
"state": "completed",
"status_details": [
"action": {
"message": "string"
"end_time": "2019-02-02T19:00:00Z",
"issue": {
"code": "10551399",
"message": "Image update complete"
"name": "initialize",
"node": {
"name": "node1"
"start_time": "2019-02-02T19:00:00Z",
"state": "failed"
"update_details": [
"elapsed_duration": "2100",
"estimated_duration": "4620",
"node": {
"name": "node1"
"phase": "Pre-update checks",
"state": "failed"
"validation_results": [
"action": {
"message": "string"
"issue": {
"message": "Validation error: Cluster HA is not configured in the cluster"
"status": "warning",
"update_check": "nfs_mounts"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
software_mcc_reference
elapsed_duration |
integer |
Elapsed duration of update time (in seconds) of MetroCluster. |
integer |
Estimated duration of update time (in seconds) of MetroCluster. |
name |
string |
Name of the site in MetroCluster. |
state |
Upgrade state of MetroCluster. |
progress_details
message |
string |
MetroCluster update progress details. |
progress_summary
message |
string |
MetroCluster update progress summary. |
metrocluster
clusters |
array[software_mcc_reference] |
List of MetroCluster sites, statuses, and active ONTAP versions.
progress_details |
progress_summary |
name |
string |
Name of the node. |
version |
string |
ONTAP version of the node.
action
code |
integer |
Error code corresponding the status error |
message |
string |
Corrective action to be taken to resolve the status error. |
issue
code |
integer |
Error code corresponding to update status |
message |
string |
Update status details |
node
name |
string |
Name of the node to be retrieved for status details. |
software_status_details_reference
action |
end_time |
string |
End time for each status phase. |
issue |
name |
string |
Name of the phase to be retrieved for status details. |
node |
start_time |
string |
Start time for each status phase. |
state |
string |
Status of the phase |
node
name |
string |
Name of the node to be retrieved for update details. |
software_update_details_reference
elapsed_duration |
integer |
Elapsed duration for each update phase |
integer |
Estimated duration for each update phase |
node |
phase |
string |
Phase details |
state |
string |
State of the update phase |
action
message |
string |
Specifies the corrective action to be taken to resolve a validation error |
issue
message |
string |
Details of the error or warning encountered by the update checks |
software_validation_reference
action |
issue |
status |
string |
Status of this update check. |
update_check |
string |
Name of the update check to be validated. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
