Retrieve NIS domain configurations of all SVMs
GET /name-services/nis
Introduced In: 9.6
Retrieves NIS domain configurations of all the SVMs. The bound_servers field indicates the successfully bound NIS servers. Lookups and authentications fail if there are no bound servers.
Related ONTAP commands
vserver services name-service nis-domain show -
vserver services name-service nis-domain show-bound
Learn more
domain  |
string  |
query  |
False  |
Filter by domain
servers  |
string  |
query  |
False  |
Filter by servers
svm.uuid  |
string  |
query  |
False  |
Filter by svm.uuid
svm.name  |
string  |
query  |
False  |
Filter by svm.name
bound_servers  |
string  |
query  |
False  |
Filter by bound_servers
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_records  |
boolean  |
query  |
False  |
return_timeout  |
integer  |
query  |
False  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
num_records  |
integer  |
Number of NIS domain records.  |
records  |
array[nis_service]  |
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "bound_servers": [
        "string"
      "domain": "string",
      "servers": [
        "string"
      "svm": {
        "name": "svm1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
next  |
self  |
_links
self  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
nis_service
_links  |
bound_servers  |
array[string]  |
domain  |
string  |
The NIS domain to which this configuration belongs.  |
servers  |
array[string]  |
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration.  |
svm  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
