Retrieve broadcast domains for the entire cluster
GET /network/ethernet/broadcast-domains
Introduced In: 9.6
Retrieves a collection of broadcast domains for the entire cluster.
Related ONTAP commands
network port broadcast-domain show
ports.name |
string |
query |
False |
Filter by ports.name |
ports.node.name |
string |
query |
False |
Filter by ports.node.name |
ports.uuid |
string |
query |
False |
Filter by ports.uuid |
name |
string |
query |
False |
Filter by name |
ipspace.name |
string |
query |
False |
Filter by ipspace.name |
ipspace.uuid |
string |
query |
False |
Filter by ipspace.uuid |
uuid |
string |
query |
False |
Filter by uuid |
mtu |
integer |
query |
False |
Filter by mtu |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
records |
array[broadcast_domain] |
"next": {
"href": "/api/resourcelink"
"records": [
"ipspace": {
"name": "exchange",
"mtu": "1500",
"name": "bd1",
"ports": [
"name": "e1b",
"node": {
"name": "node1"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input.
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
node
name |
string |
Name of node on which the port is located. |
ports
Port UUID along with readable names
_links |
name |
string |
node |
uuid |
string |
broadcast_domain
Set of ports that will receive a broadcast Ethernet packet from any of them
_links |
ipspace |
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input. |
mtu |
integer |
Maximum transmission unit, largest packet size on this network |
name |
string |
Name of the broadcast domain, scoped to its IPspace |
ports |
array[ports] |
Ports that belong to the broadcast domain |
uuid |
string |
Broadcast domain UUID |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
