Retrieve historical port performance metrics
GET /network/ethernet/ports/{uuid}/metrics
Introduced In: 9.8
Retrieves historical performance metrics for a port.
timestamp |
string |
query |
False |
Filter by timestamp |
duration |
string |
query |
False |
Filter by duration |
throughput.write |
integer |
query |
False |
Filter by throughput.write |
throughput.read |
integer |
query |
False |
Filter by throughput.read |
throughput.total |
integer |
query |
False |
Filter by throughput.total |
status |
string |
query |
False |
Filter by status |
uuid |
string |
path |
True |
Unique identifier of the port. |
interval |
string |
query |
False |
The time range for the data. Examples can be 1h, 1d, 1m, 1w, 1y. The period for each time range is as follows:
return_timeout |
integer |
query |
False |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
return_records |
boolean |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"records": [
"duration": "PT15S",
"status": "ok",
"throughput": {
"read": "200",
"total": "1000",
"write": "100"
"timestamp": "2017-01-25T11:20:13Z"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
throughput
The rate of throughput bytes per second observed at the port object.
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
records
Throughput performance for the Ethernet port.
_links |
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
status |
string |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the port object. |
timestamp |
string |
The timestamp of the performance data. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
