Retrieve an Ethernet switch port
GET /network/ethernet/switch/ports/{switch}/{identity.name}/{identity.index}
Introduced In: 9.8
Retrieves an ethernet switch port.
Related ONTAP commands
system switch ethernet interface show
switch  |
string  |
path  |
True  |
Switch Name  |
identity.name  |
string  |
path  |
True  |
Interface Name  |
identity.index  |
integer  |
path  |
True  |
Interface Index  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
configured  |
string  |
Administrative Status.  |
duplex_type  |
string  |
Duplex Settings.  |
identity  |
isl  |
boolean  |
Is configured as an ISL link.  |
mac_address  |
string  |
MAC Address.  |
mtu  |
integer  |
MTU.  |
remote_port  |
Remote port  |
speed  |
integer  |
Interface Speed(Mbps)  |
state  |
string  |
Operational Status.  |
statistics  |
These are raw counters for the device associated with the Ethernet port.  |
switch  |
The name of the specified cluster or storage switch.  |
type  |
string  |
Interface Type.  |
vlan_id  |
array[integer]  |
      "href": "/api/resourcelink"
  "configured": "string",
  "duplex_type": "string",
  "identity": {
    "index": 0,
    "name": "string",
    "number": 0
  "mac_address": "string",
  "mtu": 0,
  "remote_port": {
    "device": {
      "node": {
        "name": "node1",
      "shelf": {
        "uid": "7777841915827391056"
    "mtu": 0,
    "name": "string"
  "speed": 0,
  "state": "string",
  "statistics": {
    "receive_raw": {
      "discards": "100",
      "errors": "200",
      "packets": "500"
    "transmit_raw": {
      "discards": "100",
      "errors": "200",
      "packets": "500"
  "switch": {
    "name": "RTP-SS01-510R03(FOC223443KQ)"
  "type": "string",
  "vlan_id": [
    "integer"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
self_link
self  |
identity
index  |
integer  |
Interface Index.  |
name  |
string  |
Interface Name.  |
number  |
integer  |
Interface Number.  |
_links
self  |
node
_links  |
name  |
string  |
uuid  |
string  |
shelf
Shelf connected to this port.
_links  |
uid  |
string  |
device
Device connected to port.
node  |
shelf  |
Shelf connected to this port.  |
remote_port
Remote port
device  |
Device connected to port.  |
mtu  |
integer  |
MTU in octets  |
name  |
string  |
Port Name.  |
receive_raw
Packet receive counters for the Ethernet port.
discards  |
integer  |
Total number of discarded packets.  |
errors  |
integer  |
Number of packet errors.  |
packets  |
integer  |
Total packet count.  |
transmit_raw
Packet transmit counters for the Ethernet port.
discards  |
integer  |
errors  |
integer  |
packets  |
integer  |
statistics
receive_raw  |
Packet receive counters for the Ethernet port.  |
transmit_raw  |
Packet transmit counters for the Ethernet port.  |
switch
_links  |
name  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
