Retrieve HTTP proxy configurations for all SVMs and cluster IPspaces
GET /network/http-proxy
Introduced In: 9.7
Retrieves the HTTP proxy configurations of all the SVMs and Cluster IPspaces.
Related ONTAP commands
vserver http-proxy show
server  |
string  |
query  |
False  |
Filter by server  |
port  |
integer  |
query  |
False  |
Filter by port  |
scope  |
string  |
query  |
False  |
Filter by scope  |
ipspace.name  |
string  |
query  |
False  |
Filter by ipspace.name  |
ipspace.uuid  |
string  |
query  |
False  |
Filter by ipspace.uuid  |
svm.uuid  |
string  |
query  |
False  |
Filter by svm.uuid  |
svm.name  |
string  |
query  |
False  |
Filter by svm.name  |
uuid  |
string  |
query  |
False  |
Filter by uuid  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_records  |
boolean  |
query  |
False  |
return_timeout  |
integer  |
query  |
False  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
num_records  |
integer  |
Number of HTTP proxy records  |
records  |
array[network_http_proxy]  |
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "ipspace": {
        "name": "exchange",
      "port": "3128",
      "scope": "string",
      "server": "string",
      "svm": {
        "name": "svm1",
      "uuid": "string"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
next  |
self  |
_links
self  |
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input.
_links  |
name  |
string  |
IPspace name  |
uuid  |
string  |
IPspace UUID  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
network_http_proxy
_links  |
ipspace  |
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input.  |
port  |
integer  |
The port number on which the HTTP proxy service is configured on the proxy server.  |
scope  |
string  |
Set to “svm” for proxy owned by an SVM. Otherwise, set to "cluster".  |
server  |
string  |
The fully qualified domain name (FQDN) or IP address of the proxy server.  |
svm  |
uuid  |
string  |
The UUID that uniquely identifies the HTTP proxy.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
