Retrieve all BGP peer group details for VIP
GET /network/ip/bgp/peer-groups
Introduced In: 9.7
Retrieves the details of all BGP peer groups for VIP.
Related ONTAP Commands
network bgp peer-group show
state |
string |
query |
False |
Filter by state |
local.port.name |
string |
query |
False |
Filter by local.port.name |
local.port.node.name |
string |
query |
False |
Filter by local.port.node.name |
local.port.uuid |
string |
query |
False |
Filter by local.port.uuid |
local.interface.name |
string |
query |
False |
Filter by local.interface.name |
local.interface.uuid |
string |
query |
False |
Filter by local.interface.uuid |
local.interface.ip.address |
string |
query |
False |
Filter by local.interface.ip.address |
uuid |
string |
query |
False |
Filter by uuid |
peer.asn |
integer |
query |
False |
Filter by peer.asn |
peer.address |
string |
query |
False |
Filter by peer.address |
name |
string |
query |
False |
Filter by name |
ipspace.name |
string |
query |
False |
Filter by ipspace.name |
ipspace.uuid |
string |
query |
False |
Filter by ipspace.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
records |
array[bgp_peer_group] |
"next": {
"href": "/api/resourcelink"
"num_records": "1",
"records": [
"ipspace": {
"name": "exchange",
"local": {
"interface": {
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"port": {
"name": "e1b",
"node": {
"name": "node1"
"name": "bgpv4peer",
"peer": {
"state": "string",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ipspace
Either the UUID or name is supplied on input.
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
ip
IP information
address |
string |
IPv4 or IPv6 address |
interface
_links |
ip |
IP information |
name |
string |
The name of the interface. |
uuid |
string |
The UUID that uniquely identifies the interface. |
ip
IP information to create a new interface.
address |
string |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length. |
node
name |
string |
Name of node on which the port is located. |
port
_links |
name |
string |
node |
uuid |
string |
local
Information describing the local interface that is being used to peer with a router using BGP. On a POST operation, an existing BGP interface is used by specifying the interface, or create a new one by specifying the port and IP address.
interface |
port |
peer
Information describing the router to peer with
address |
string |
Peer router address |
asn |
integer |
Autonomous system number of peer |
bgp_peer_group
A BGP peer group between a local network interface and a router, for the purpose of announcing VIP interface locations for SVMs in this IPspace.
ipspace |
Either the UUID or name is supplied on input. |
local |
Information describing the local interface that is being used to peer with a router using BGP. On a POST operation, an existing BGP interface is used by specifying the interface, or create a new one by specifying the port and IP address. |
name |
string |
Name of the peer group |
peer |
Information describing the router to peer with |
state |
string |
State of the peer group |
uuid |
string |
UUID of the peer group |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
