Retrieve all IP interface details
GET /network/ip/interfaces
Introduced In: 9.6
Retrieves the details of all IP interfaces.
Related ONTAP Commands
network interface show
location.node.name |
string |
query |
False |
Filter by location.node.name |
location.node.uuid |
string |
query |
False |
Filter by location.node.uuid |
location.auto_revert |
boolean |
query |
False |
Filter by location.auto_revert |
location.is_home |
boolean |
query |
False |
Filter by location.is_home |
location.failover |
string |
query |
False |
Filter by location.failover |
location.home_node.name |
string |
query |
False |
Filter by location.home_node.name |
location.home_node.uuid |
string |
query |
False |
Filter by location.home_node.uuid |
location.home_port.name |
string |
query |
False |
Filter by location.home_port.name |
location.home_port.node.name |
string |
query |
False |
Filter by location.home_port.node.name |
location.home_port.uuid |
string |
query |
False |
Filter by location.home_port.uuid |
location.port.name |
string |
query |
False |
Filter by location.port.name |
location.port.node.name |
string |
query |
False |
Filter by location.port.node.name |
location.port.uuid |
string |
query |
False |
Filter by location.port.uuid |
enabled |
boolean |
query |
False |
Filter by enabled |
vip |
boolean |
query |
False |
Filter by vip |
scope |
string |
query |
False |
Filter by scope |
services |
string |
query |
False |
Filter by services |
name |
string |
query |
False |
Filter by name |
ipspace.name |
string |
query |
False |
Filter by ipspace.name |
ipspace.uuid |
string |
query |
False |
Filter by ipspace.uuid |
metric.status |
string |
query |
False |
Filter by metric.status
metric.throughput.write |
integer |
query |
False |
Filter by metric.throughput.write
metric.throughput.read |
integer |
query |
False |
Filter by metric.throughput.read
metric.throughput.total |
integer |
query |
False |
Filter by metric.throughput.total
metric.timestamp |
string |
query |
False |
Filter by metric.timestamp
metric.duration |
string |
query |
False |
Filter by metric.duration
uuid |
string |
query |
False |
Filter by uuid |
state |
string |
query |
False |
Filter by state |
ip.address |
string |
query |
False |
Filter by ip.address |
ip.family |
string |
query |
False |
Filter by ip.family |
ip.netmask |
string |
query |
False |
Filter by ip.netmask |
statistics.timestamp |
string |
query |
False |
Filter by statistics.timestamp
statistics.status |
string |
query |
False |
Filter by statistics.status
statistics.throughput_raw.write |
integer |
query |
False |
Filter by statistics.throughput_raw.write
statistics.throughput_raw.read |
integer |
query |
False |
Filter by statistics.throughput_raw.read
statistics.throughput_raw.total |
integer |
query |
False |
Filter by statistics.throughput_raw.total
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
service_policy.uuid |
string |
query |
False |
Filter by service_policy.uuid |
service_policy.name |
string |
query |
False |
Filter by service_policy.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
records |
array[ip_interface] |
"next": {
"href": "/api/resourcelink"
"num_records": "1",
"records": [
"ip": {
"address": "10.10.10.7",
"family": "string",
"netmask": "24"
"ipspace": {
"name": "exchange",
"location": {
"failover": "string",
"home_node": {
"name": "node1",
"home_port": {
"name": "e1b",
"node": {
"name": "node1"
"node": {
"name": "node1",
"port": {
"name": "e1b",
"node": {
"name": "node1"
"metric": {
"duration": "PT15S",
"status": "ok",
"throughput": {
"read": "200",
"total": "1000",
"write": "100"
"timestamp": "2017-01-25T11:20:13Z"
"name": "dataLif1",
"scope": "string",
"service_policy": {
"name": "default-intercluster",
"services": [
"data_nfs"
"state": "string",
"statistics": {
"status": "ok",
"throughput_raw": {
"read": "200",
"total": "1000",
"write": "100"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ip_info
IP information
address |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length. |
ipspace
Either the UUID or name must be supplied on POST for cluster-scoped objects.
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
broadcast_domain
Broadcast domain UUID along with a readable name.
_links |
name |
string |
Name of the broadcast domain, scoped to its IPspace |
uuid |
string |
Broadcast domain UUID |
home_node
_links |
name |
string |
uuid |
string |
node
name |
string |
Name of node on which the port is located. |
home_port
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
_links |
name |
string |
node |
uuid |
string |
node
_links |
name |
string |
uuid |
string |
port
_links |
name |
string |
node |
uuid |
string |
location
Current or home location can be modified. Specifying a port implies a node. Specifying a node allows an appropriate port to be automatically selected. Ports are not valid and not shown for VIP interfaces. For POST, broadcast_domain can be specified alone or with home_node.
auto_revert |
boolean |
failover |
string |
Defines where an interface may failover. |
home_node |
home_port |
Port UUID along with readable names. Either the UUID or both names may be supplied on input. |
is_home |
boolean |
node |
port |
throughput
The rate of throughput bytes per second observed at the interface.
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
metric
The most recent sample of I/O metrics for the interface.
_links |
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
status |
string |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the interface. |
timestamp |
string |
The timestamp of the performance data. |
service_policy
_links |
name |
string |
uuid |
string |
throughput_raw
Throughput bytes observed at the interface. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
read |
integer |
total |
integer |
write |
integer |
statistics
The real time I/O statistics for the interface.
status |
string |
throughput_raw |
Throughput bytes observed at the interface. This can be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
svm
Applies only to SVM-scoped objects. Either the UUID or name must be supplied on POST.
_links |
name |
string |
The name of the SVM. |
uuid |
string |
ip_interface
_links |
enabled |
boolean |
The administrative state of the interface. |
ip |
IP information |
ipspace |
Either the UUID or name must be supplied on POST for cluster-scoped objects. |
location |
Current or home location can be modified. Specifying a port implies a node. Specifying a node allows an appropriate port to be automatically selected. Ports are not valid and not shown for VIP interfaces. For POST, broadcast_domain can be specified alone or with home_node. |
metric |
The most recent sample of I/O metrics for the interface. |
name |
string |
Interface name |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
service_policy |
services |
array[string] |
The services associated with the interface. |
state |
string |
The operational state of the interface. |
statistics |
The real time I/O statistics for the interface. |
svm |
Applies only to SVM-scoped objects. Either the UUID or name must be supplied on POST. |
uuid |
string |
The UUID that uniquely identifies the interface. |
vip |
boolean |
True for a VIP interface, whose location is announced via BGP. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
