Retrieve the UNIX symbolic link mapping for CIFS clients
GET /protocols/cifs/unix-symlink-mapping/{svm.uuid}/{unix_path}
Introduced In: 9.6
Retrieves a UNIX symbolic link mapping for CIFS clients.
Related ONTAP commands
vserver cifs symlink show
Learn more
unix_path  |
string  |
path  |
True  |
UNIX symbolic link path  |
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
svm  |
target  |
unix_path  |
string  |
Specifies the UNIX path prefix to be matched for the mapping.  |
      "href": "/api/resourcelink"
  "svm": {
    "name": "svm1",
  "target": {
    "locality": "string",
    "path": "/dir1/dir2/",
    "server": "ENGCIFS",
    "share": "ENG_SHARE"
  "unix_path": "/mnt/eng_volume/"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
cifs_target
home_directory  |
boolean  |
Specify if the destination share is a home directory.  |
locality  |
string  |
Specifies whether the CIFS symbolic link is a local link or wide link. The following values are supported:
path  |
string  |
Specifies the CIFS path on the destination to which the symbolic link maps. The final path is generated by concatenating the CIFS server name, the share name, the cifs-path and the remaining path in the symbolic link left after the prefix match. This value is specified by using a UNIX-style path name. The trailing forward slash is required for the full path name to be properly interpreted.  |
server  |
string  |
Specifies the destination CIFS server where the UNIX symbolic link is pointing. This field is mandatory if the locality of the symbolic link is 'widelink'. You can specify the value in any of the following formats:
share  |
string  |
Specifies the CIFS share name on the destination CIFS server to which the UNIX symbolic link is pointing.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
