Retrieve the FPolicy configuration for an SVM
GET /protocols/fpolicy/{svm.uuid}
Introduced In: 9.6
Retrieves an FPolicy configuration of an SVM.
Related ONTAP commands
fpolicy show -
fpolicy policy show -
fpolicy policy scope show -
fpolicy policy event show -
fpolicy policy external-engine show
Learn more
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
engines  |
array[fpolicy_engine]  |
events  |
array[fpolicy_event]  |
policies  |
array[fpolicy_policy]  |
svm  |
      "href": "/api/resourcelink"
  "engines": [
      "name": "fp_ex_eng",
      "port": "9876",
      "primary_servers": [
        "10.132.145.20",
        "10.140.101.109"
      "secondary_servers": [
        "10.132.145.20",
        "10.132.145.21"
      "type": "string"
  "events": [
      "name": "event_nfs_close",
      "protocol": "string"
  "policies": [
      "engine": {
        "name": "string"
      "events": [
        "event_nfs_close",
        "event_open"
      "name": "fp_policy_1",
      "scope": {
        "exclude_export_policies": [
          "string"
        "exclude_extension": [
          "string"
        "exclude_shares": [
          "string"
        "exclude_volumes": [
          "vol1",
          "vol_svm1",
        "include_export_policies": [
          "string"
        "include_extension": [
          "string"
        "include_shares": [
          "sh1",
          "share_cifs"
        "include_volumes": [
          "vol1",
          "vol_svm1"
  "svm": {
    "name": "svm1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
fpolicy_engine
The engine defines how ONTAP makes and manages connections to external FPolicy servers.
name  |
string  |
Specifies the name to assign to the external server configuration.  |
port  |
integer  |
Port number of the FPolicy server application.  |
primary_servers  |
array[string]  |
secondary_servers  |
array[string]  |
type  |
string  |
The notification mode determines what ONTAP does after sending notifications to FPolicy servers. The possible values are:
file_operations
Specifies the file operations for the FPolicy event. You must specify a valid protocol in the protocol parameter. The event will check the operations specified from all client requests using the protocol.
close  |
boolean  |
File close operations  |
create  |
boolean  |
File create operations  |
create_dir  |
boolean  |
Directory create operations  |
delete  |
boolean  |
File delete operations  |
delete_dir  |
boolean  |
Directory delete operations  |
getattr  |
boolean  |
Get attribute operations  |
link  |
boolean  |
Link operations  |
lookup  |
boolean  |
Lookup operations  |
open  |
boolean  |
File open operations  |
read  |
boolean  |
File read operations  |
rename  |
boolean  |
File rename operations  |
rename_dir  |
boolean  |
Directory rename operations  |
setattr  |
boolean  |
Set attribute operations  |
symlink  |
boolean  |
Symbolic link operations  |
write  |
boolean  |
File write operations  |
filters
Specifies the list of filters for a given file operation for the specified protocol. When you specify the filters, you must specify the valid protocols and a valid file operations.
close_with_modification  |
boolean  |
Filter the client request for close with modification.  |
close_with_read  |
boolean  |
Filter the client request for close with read.  |
close_without_modification  |
boolean  |
Filter the client request for close without modification.  |
exclude_directory  |
boolean  |
Filter the client requests for directory operations. When this filter is specified directory operations are not monitored.  |
first_read  |
boolean  |
Filter the client requests for the first-read.  |
first_write  |
boolean  |
Filter the client requests for the first-write.  |
monitor_ads  |
boolean  |
Filter the client request for alternate data stream.  |
offline_bit  |
boolean  |
Filter the client request for offline bit set. FPolicy server receives notification only when offline files are accessed.  |
open_with_delete_intent  |
boolean  |
Filter the client request for open with delete intent.  |
open_with_write_intent  |
boolean  |
Filter the client request for open with write intent.  |
setattr_with_access_time_change  |
boolean  |
Filter the client setattr requests for changing the access time of a file or directory.  |
setattr_with_allocation_size_change  |
boolean  |
Filter the client setattr requests for changing the allocation size of a file.  |
setattr_with_creation_time_change  |
boolean  |
Filter the client setattr requests for changing the creation time of a file or directory.  |
setattr_with_dacl_change  |
boolean  |
Filter the client setattr requests for changing dacl on a file or directory.  |
setattr_with_group_change  |
boolean  |
Filter the client setattr requests for changing group of a file or directory.  |
setattr_with_mode_change  |
boolean  |
Filter the client setattr requests for changing the mode bits on a file or directory.  |
setattr_with_modify_time_change  |
boolean  |
Filter the client setattr requests for changing the modification time of a file or directory.  |
setattr_with_owner_change  |
boolean  |
Filter the client setattr requests for changing owner of a file or directory.  |
setattr_with_sacl_change  |
boolean  |
Filter the client setattr requests for changing sacl on a file or directory.  |
setattr_with_size_change  |
boolean  |
Filter the client setattr requests for changing the size of a file.  |
write_with_size_change  |
boolean  |
Filter the client request for write with size change.  |
fpolicy_event
The information that a FPolicy process needs to determine what file access operations to monitor and for which of the monitored events notifications should be sent to the external FPolicy server.
file_operations  |
Specifies the file operations for the FPolicy event. You must specify a valid protocol in the protocol parameter. The event will check the operations specified from all client requests using the protocol.  |
filters  |
Specifies the list of filters for a given file operation for the specified protocol. When you specify the filters, you must specify the valid protocols and a valid file operations.  |
name  |
string  |
Specifies the name of the FPolicy event.  |
protocol  |
string  |
Protocol for which event is created. If you specify protocol, then you must also specify a valid value for the file operation parameters. The value of this parameter must be one of the following:
volume_monitoring  |
boolean  |
Specifies whether volume operation monitoring is required.  |
fpolicy_engine_reference
FPolicy external engine
_links  |
name  |
string  |
The name of the FPolicy external engine.  |
fpolicy_event_reference
FPolicy events
_links  |
name  |
string  |
scope
exclude_export_policies  |
array[string]  |
exclude_extension  |
array[string]  |
exclude_shares  |
array[string]  |
exclude_volumes  |
array[string]  |
include_export_policies  |
array[string]  |
include_extension  |
array[string]  |
include_shares  |
array[string]  |
include_volumes  |
array[string]  |
fpolicy_policy
enabled  |
boolean  |
Specifies if the policy is enabled on the SVM or not. If no value is mentioned for this field but priority is set, then this policy will be enabled.  |
engine  |
FPolicy external engine  |
events  |
array[fpolicy_event_reference]  |
mandatory  |
boolean  |
Specifies what action to take on a file access event in a case when all primary and secondary servers are down or no response is received from the FPolicy servers within a given timeout period. When this parameter is set to true, file access events will be denied under these circumstances.  |
name  |
string  |
Specifies the name of the policy.  |
priority  |
integer  |
Specifies the priority that is assigned to this policy.  |
scope  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
