Retrieve NDMP node configurations for all nodes
GET /protocols/ndmp/nodes
Introduced In: 9.7
Retrieves NDMP node configurations for all of the nodes.
Related ONTAP commands
system services ndmp show
Learn more
authentication_types |
string |
query |
False |
Filter by authentication_types |
user |
string |
query |
False |
Filter by user |
enabled |
boolean |
query |
False |
Filter by enabled |
node.name |
string |
query |
False |
Filter by node.name |
node.uuid |
string |
query |
False |
Filter by node.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[ndmp_node] |
"next": {
"href": "/api/resourcelink"
"records": [
"authentication_types": [
"plaintext",
"challenge"
"enabled": 1,
"node": {
"name": "node1",
"user": "ndmp_user"
Status: Default
ONTAP Error Response codes
| Error code | Description |
68812801 |
Node-scoped operations are not allowed in an SVM-scope. |
68812804 |
Failed to get the node name from the specified node UUID. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
Storage system node
_links |
name |
string |
uuid |
string |
ndmp_node
_links |
array[string] |
NDMP authentication types. |
enabled |
boolean |
Is the NDMP service enabled? |
node |
Storage system node |
user |
string |
NDMP user ID |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
