      Retrieve the NDMP configuration for an SVM
GET /protocols/ndmp/svms/{svm.uuid}
Introduced In: 9.7
Retrieves an NDMP configuration for a specific SVM.
Related ONTAP commands
vserver services ndmp show
Learn more
svm.uuid  |
string  |
path  |
True  |
SVM UUID  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
authentication_types  |
array[string]  |
NDMP authentication types.  |
enabled  |
boolean  |
Is the NDMP service enabled on the SVM?  |
svm  |
      "href": "/api/resourcelink"
  "authentication_types": [
    "plaintext",
    "challenge"
  "enabled": 1,
  "svm": {
    "name": "svm1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
