REST API reference
Retrieve export policies
GET /protocols/nfs/export-policies
Introduced In: 9.6
Retrieves export policies.
  • vserver export-policy show
  • vserver export-policy rule show
id
integer
query
False
Filter by id
name
string
query
False
Filter by name
rules.anonymous_user
string
query
False
Filter by rules.anonymous_user
rules.index
integer
query
False
Filter by rules.index
rules.clients.match
string
query
False
Filter by rules.clients.match
rules.rw_rule
string
query
False
Filter by rules.rw_rule
rules.protocols
string
query
False
Filter by rules.protocols
rules.superuser
string
query
False
Filter by rules.superuser
rules.ro_rule
string
query
False
Filter by rules.ro_rule
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of export policy records
records
array[export_policy]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "id": 0,
      "name": "string",
      "rules": [
          "anonymous_user": "string",
          "clients": [
              "match": "0.0.0.0/0"
          "index": 0,
          "protocols": [
            "string"
          "ro_rule": [
            "string"
          "rw_rule": [
            "string"
          "superuser": [
            "string"
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
export_client
match
string
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
  • As a hostname; for instance, host1
  • As an IPv4 address; for instance, 10.1.12.24
  • As an IPv6 address; for instance, fd20:8b1e:b255:4071::100:1
  • As an IPv4 address with a subnet mask expressed as a number of bits; for instance, 10.1.12.0/24
  • As an IPv6 address with a subnet mask expressed as a number of bits; for instance, fd20:8b1e:b255:4071::/64
  • As an IPv4 address with a network mask; for instance, 10.1.16.0/255.255.255.0
  • As a netgroup, with the netgroup name preceded by the @ character; for instance, @eng
  • As a domain name preceded by the . character; for instance, .example.com
export_rule
_links
_links
anonymous_user
string
User ID To Which Anonymous Users Are Mapped.
clients
array[export_client]
Array of client matches
index
integer
Index of the rule within the export policy.
protocols
array[string]
ro_rule
array[string]
Authentication flavors that the read-only access rule governs
rw_rule
array[string]
Authentication flavors that the read/write access rule governs
superuser
array[string]
Authentication flavors that the superuser security type governs
svm
_links
_links
name
string
The name of the SVM.
uuid
string
export_policy
_links
_links
id
integer
Export Policy ID
name
string
Export Policy Name
rules
array[export_rule]
Rules of the Export Policy.
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
