Retrieve a Kerberos realm
GET /protocols/nfs/kerberos/realms/{svm.uuid}/{name}
Introduced In: 9.6
Retrieves a Kerberos realm.
vserver nfs kerberos realm show
Learn more
svm.uuid  |
string  |
path  |
True  |
SVM UUID  |
name  |
string  |
path  |
True  |
Kerberos realm  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
ad_server  |
comment  |
string  |
Comment  |
encryption_types  |
array[string]  |
kdc  |
name  |
string  |
Kerberos realm  |
svm  |
      "href": "/api/resourcelink"
  "ad_server": {
    "address": "1.2.3.4",
    "name": "string"
  "comment": "string",
  "encryption_types": [
    "string"
  "kdc": {
    "ip": "1.2.3.4",
    "port": "88",
    "vendor": "string"
  "name": "string",
  "svm": {
    "name": "svm1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
ad_server
address  |
string  |
Active Directory server IP address  |
name  |
string  |
Active Directory server name  |
kdc
ip  |
string  |
KDC IP address  |
port  |
integer  |
KDC port  |
vendor  |
string  |
Key Distribution Center (KDC) vendor. Following values are suported:
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
