Retrieve the NFS configuration for SVMs
GET /protocols/nfs/services
Introduced In: 9.6
Retrieves the NFS configuration of SVMs.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
statistics.* -
metric.*
Related ONTAP commands
vserver nfs show -
vserver nfs status
Learn more
enabled |
boolean |
query |
False |
Filter by enabled |
transport.udp_enabled |
boolean |
query |
False |
Filter by transport.udp_enabled |
transport.tcp_enabled |
boolean |
query |
False |
Filter by transport.tcp_enabled |
extended_groups_limit |
integer |
query |
False |
Filter by extended_groups_limit
positive_cached_credential_ttl |
integer |
query |
False |
Filter by positive_cached_credential_ttl
metric.v3.throughput.write |
integer |
query |
False |
Filter by metric.v3.throughput.write
metric.v3.throughput.read |
integer |
query |
False |
Filter by metric.v3.throughput.read
metric.v3.throughput.total |
integer |
query |
False |
Filter by metric.v3.throughput.total
metric.v3.duration |
string |
query |
False |
Filter by metric.v3.duration
metric.v3.timestamp |
string |
query |
False |
Filter by metric.v3.timestamp
metric.v3.status |
string |
query |
False |
Filter by metric.v3.status
metric.v3.iops.total |
integer |
query |
False |
Filter by metric.v3.iops.total
metric.v3.iops.read |
integer |
query |
False |
Filter by metric.v3.iops.read
metric.v3.iops.other |
integer |
query |
False |
Filter by metric.v3.iops.other
metric.v3.iops.write |
integer |
query |
False |
Filter by metric.v3.iops.write
metric.v3.latency.total |
integer |
query |
False |
Filter by metric.v3.latency.total
metric.v3.latency.read |
integer |
query |
False |
Filter by metric.v3.latency.read
metric.v3.latency.other |
integer |
query |
False |
Filter by metric.v3.latency.other
metric.v3.latency.write |
integer |
query |
False |
Filter by metric.v3.latency.write
metric.v41.throughput.write |
integer |
query |
False |
Filter by metric.v41.throughput.write
metric.v41.throughput.read |
integer |
query |
False |
Filter by metric.v41.throughput.read
metric.v41.throughput.total |
integer |
query |
False |
Filter by metric.v41.throughput.total
metric.v41.duration |
string |
query |
False |
Filter by metric.v41.duration
metric.v41.timestamp |
string |
query |
False |
Filter by metric.v41.timestamp
metric.v41.status |
string |
query |
False |
Filter by metric.v41.status
metric.v41.iops.total |
integer |
query |
False |
Filter by metric.v41.iops.total
metric.v41.iops.read |
integer |
query |
False |
Filter by metric.v41.iops.read
metric.v41.iops.other |
integer |
query |
False |
Filter by metric.v41.iops.other
metric.v41.iops.write |
integer |
query |
False |
Filter by metric.v41.iops.write
metric.v41.latency.total |
integer |
query |
False |
Filter by metric.v41.latency.total
metric.v41.latency.read |
integer |
query |
False |
Filter by metric.v41.latency.read
metric.v41.latency.other |
integer |
query |
False |
Filter by metric.v41.latency.other
metric.v41.latency.write |
integer |
query |
False |
Filter by metric.v41.latency.write
metric.v4.throughput.write |
integer |
query |
False |
Filter by metric.v4.throughput.write
metric.v4.throughput.read |
integer |
query |
False |
Filter by metric.v4.throughput.read
metric.v4.throughput.total |
integer |
query |
False |
Filter by metric.v4.throughput.total
metric.v4.duration |
string |
query |
False |
Filter by metric.v4.duration
metric.v4.timestamp |
string |
query |
False |
Filter by metric.v4.timestamp
metric.v4.status |
string |
query |
False |
Filter by metric.v4.status
metric.v4.iops.total |
integer |
query |
False |
Filter by metric.v4.iops.total
metric.v4.iops.read |
integer |
query |
False |
Filter by metric.v4.iops.read
metric.v4.iops.other |
integer |
query |
False |
Filter by metric.v4.iops.other
metric.v4.iops.write |
integer |
query |
False |
Filter by metric.v4.iops.write
metric.v4.latency.total |
integer |
query |
False |
Filter by metric.v4.latency.total
metric.v4.latency.read |
integer |
query |
False |
Filter by metric.v4.latency.read
metric.v4.latency.other |
integer |
query |
False |
Filter by metric.v4.latency.other
metric.v4.latency.write |
integer |
query |
False |
Filter by metric.v4.latency.write
protocol.v41_enabled |
boolean |
query |
False |
Filter by protocol.v41_enabled |
protocol.v3_enabled |
boolean |
query |
False |
Filter by protocol.v3_enabled |
protocol.v41_features.pnfs_enabled |
boolean |
query |
False |
Filter by protocol.v41_features.pnfs_enabled |
protocol.v41_features.write_delegation_enabled |
boolean |
query |
False |
Filter by protocol.v41_features.write_delegation_enabled |
protocol.v41_features.acl_enabled |
boolean |
query |
False |
Filter by protocol.v41_features.acl_enabled |
protocol.v41_features.read_delegation_enabled |
boolean |
query |
False |
Filter by protocol.v41_features.read_delegation_enabled |
protocol.v40_features.read_delegation_enabled |
boolean |
query |
False |
Filter by protocol.v40_features.read_delegation_enabled |
protocol.v40_features.write_delegation_enabled |
boolean |
query |
False |
Filter by protocol.v40_features.write_delegation_enabled |
protocol.v40_features.acl_enabled |
boolean |
query |
False |
Filter by protocol.v40_features.acl_enabled |
protocol.v4_64bit_identifiers_enabled |
boolean |
query |
False |
Filter by protocol.v4_64bit_identifiers_enabled
protocol.v3_64bit_identifiers_enabled |
boolean |
query |
False |
Filter by protocol.v3_64bit_identifiers_enabled
protocol.v40_enabled |
boolean |
query |
False |
Filter by protocol.v40_enabled |
protocol.v4_id_domain |
string |
query |
False |
Filter by protocol.v4_id_domain |
statistics.v41.latency_raw.total |
integer |
query |
False |
Filter by statistics.v41.latency_raw.total
statistics.v41.latency_raw.read |
integer |
query |
False |
Filter by statistics.v41.latency_raw.read
statistics.v41.latency_raw.other |
integer |
query |
False |
Filter by statistics.v41.latency_raw.other
statistics.v41.latency_raw.write |
integer |
query |
False |
Filter by statistics.v41.latency_raw.write
statistics.v41.timestamp |
string |
query |
False |
Filter by statistics.v41.timestamp
statistics.v41.iops_raw.total |
integer |
query |
False |
Filter by statistics.v41.iops_raw.total
statistics.v41.iops_raw.read |
integer |
query |
False |
Filter by statistics.v41.iops_raw.read
statistics.v41.iops_raw.other |
integer |
query |
False |
Filter by statistics.v41.iops_raw.other
statistics.v41.iops_raw.write |
integer |
query |
False |
Filter by statistics.v41.iops_raw.write
statistics.v41.throughput_raw.write |
integer |
query |
False |
Filter by statistics.v41.throughput_raw.write
statistics.v41.throughput_raw.read |
integer |
query |
False |
Filter by statistics.v41.throughput_raw.read
statistics.v41.throughput_raw.total |
integer |
query |
False |
Filter by statistics.v41.throughput_raw.total
statistics.v41.status |
string |
query |
False |
Filter by statistics.v41.status
statistics.v3.latency_raw.total |
integer |
query |
False |
Filter by statistics.v3.latency_raw.total
statistics.v3.latency_raw.read |
integer |
query |
False |
Filter by statistics.v3.latency_raw.read
statistics.v3.latency_raw.other |
integer |
query |
False |
Filter by statistics.v3.latency_raw.other
statistics.v3.latency_raw.write |
integer |
query |
False |
Filter by statistics.v3.latency_raw.write
statistics.v3.timestamp |
string |
query |
False |
Filter by statistics.v3.timestamp
statistics.v3.iops_raw.total |
integer |
query |
False |
Filter by statistics.v3.iops_raw.total
statistics.v3.iops_raw.read |
integer |
query |
False |
Filter by statistics.v3.iops_raw.read
statistics.v3.iops_raw.other |
integer |
query |
False |
Filter by statistics.v3.iops_raw.other
statistics.v3.iops_raw.write |
integer |
query |
False |
Filter by statistics.v3.iops_raw.write
statistics.v3.throughput_raw.write |
integer |
query |
False |
Filter by statistics.v3.throughput_raw.write
statistics.v3.throughput_raw.read |
integer |
query |
False |
Filter by statistics.v3.throughput_raw.read
statistics.v3.throughput_raw.total |
integer |
query |
False |
Filter by statistics.v3.throughput_raw.total
statistics.v3.status |
string |
query |
False |
Filter by statistics.v3.status
statistics.v4.latency_raw.total |
integer |
query |
False |
Filter by statistics.v4.latency_raw.total
statistics.v4.latency_raw.read |
integer |
query |
False |
Filter by statistics.v4.latency_raw.read
statistics.v4.latency_raw.other |
integer |
query |
False |
Filter by statistics.v4.latency_raw.other
statistics.v4.latency_raw.write |
integer |
query |
False |
Filter by statistics.v4.latency_raw.write
statistics.v4.timestamp |
string |
query |
False |
Filter by statistics.v4.timestamp
statistics.v4.iops_raw.total |
integer |
query |
False |
Filter by statistics.v4.iops_raw.total
statistics.v4.iops_raw.read |
integer |
query |
False |
Filter by statistics.v4.iops_raw.read
statistics.v4.iops_raw.other |
integer |
query |
False |
Filter by statistics.v4.iops_raw.other
statistics.v4.iops_raw.write |
integer |
query |
False |
Filter by statistics.v4.iops_raw.write
statistics.v4.throughput_raw.write |
integer |
query |
False |
Filter by statistics.v4.throughput_raw.write
statistics.v4.throughput_raw.read |
integer |
query |
False |
Filter by statistics.v4.throughput_raw.read
statistics.v4.throughput_raw.total |
integer |
query |
False |
Filter by statistics.v4.throughput_raw.total
statistics.v4.status |
string |
query |
False |
Filter by statistics.v4.status
state |
string |
query |
False |
Filter by state |
auth_sys_extended_groups_enabled |
boolean |
query |
False |
Filter by auth_sys_extended_groups_enabled
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
rquota_enabled |
boolean |
query |
False |
Filter by rquota_enabled
showmount_enabled |
boolean |
query |
False |
Filter by showmount_enabled
vstorage_enabled |
boolean |
query |
False |
Filter by vstorage_enabled |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of NFS Server Records |
records |
array[nfs_service] |
"next": {
"href": "/api/resourcelink"
"records": [
"extended_groups_limit": "32",
"metric": {
"v3": {
"duration": "PT15S",
"iops": {
"read": "200",
"total": "1000",
"write": "100"
"latency": {
"read": "200",
"total": "1000",
"write": "100"
"status": "ok",
"throughput": {
"read": "200",
"total": "1000",
"write": "100"
"timestamp": "2017-01-25T11:20:13Z"
"v4": {
"iops": {
"read": "200",
"total": "1000",
"write": "100"
"latency": {
"read": "200",
"total": "1000",
"write": "100"
"status": "ok",
"throughput": {
"read": "200",
"total": "1000",
"write": "100"
"v41": {
"iops": {
"read": "200",
"total": "1000",
"write": "100"
"latency": {
"read": "200",
"total": "1000",
"write": "100"
"status": "ok",
"throughput": {
"read": "200",
"total": "1000",
"write": "100"
"positive_cached_credential_ttl": "7200000",
"protocol": {
"v4_id_domain": "string"
"state": "string",
"statistics": {
"v3": {
"iops_raw": {
"read": "200",
"total": "1000",
"write": "100"
"latency_raw": {
"read": "200",
"total": "1000",
"write": "100"
"status": "ok",
"throughput_raw": {
"read": "200",
"total": "1000",
"write": "100"
"v4": {
"iops_raw": {
"read": "200",
"total": "1000",
"write": "100"
"latency_raw": {
"read": "200",
"total": "1000",
"write": "100"
"status": "ok",
"throughput_raw": {
"read": "200",
"total": "1000",
"write": "100"
"v41": {
"iops_raw": {
"read": "200",
"total": "1000",
"write": "100"
"latency_raw": {
"read": "200",
"total": "1000",
"write": "100"
"status": "ok",
"throughput_raw": {
"read": "200",
"total": "1000",
"write": "100"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
read |
integer |
total |
integer |
write |
integer |
v3
The NFSv3 operations
_links |
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
v4
The NFSv4 operations
_links |
duration |
string |
iops |
latency |
status |
string |
throughput |
timestamp |
string |
v41
The NFSv4.1 operations
_links |
duration |
string |
iops |
latency |
status |
string |
throughput |
timestamp |
string |
metric
Historical performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol.
v3 |
The NFSv3 operations |
v4 |
The NFSv4 operations |
v41 |
The NFSv4.1 operations |
v40_features
acl_enabled |
boolean |
Specifies whether NFSv4.0 ACLs is enabled. |
boolean |
Specifies whether NFSv4.0 Read Delegation is enabled. |
boolean |
Specifies whether NFSv4.0 Write Delegation is enabled. |
v41_features
acl_enabled |
boolean |
Specifies whether NFSv4.1 or later ACLs is enabled. |
pnfs_enabled |
boolean |
Specifies whether NFSv4.1 or later Parallel NFS is enabled. |
boolean |
Specifies whether NFSv4.1 or later Read Delegation is enabled. |
boolean |
Specifies whether NFSv4.1 or later Write Delegation is enabled. |
protocol
boolean |
Specifies whether 64-bit support for NFSv3 FSIDs and file IDs is enabled. |
v3_enabled |
boolean |
Specifies whether NFSv3 protocol is enabled. |
v40_enabled |
boolean |
Specifies whether NFSv4.0 protocol is enabled. |
v40_features |
v41_enabled |
boolean |
Specifies whether NFSv4.1 or later protocol is enabled. |
v41_features |
boolean |
Specifies whether 64-bit support for NFSv4.x FSIDs and file IDs is enabled. |
v4_id_domain |
string |
Specifies the domain portion of the string form of user and group names as defined by the NFSv4 protocol. |
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read |
integer |
total |
integer |
write |
integer |
v3
iops_raw |
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput_raw |
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
v4
iops_raw |
latency_raw |
status |
string |
throughput_raw |
timestamp |
string |
v41
iops_raw |
latency_raw |
status |
string |
throughput_raw |
timestamp |
string |
statistics
Realtime performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol.
v3 |
v4 |
v41 |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
transport
tcp_enabled |
boolean |
Specifies whether TCP transports are enabled on the server. |
udp_enabled |
boolean |
Specifies whether UDP transports are enabled on the server. |
nfs_service
_links |
boolean |
Specifies whether or not extended groups support over AUTH_SYS is enabled. |
enabled |
boolean |
Specifies if the NFS service is administratively enabled. |
integer |
Specifies the maximum auxillary groups supported over AUTH_SYS and RPCSEC_GSS. |
metric |
Historical performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol. |
integer |
Specifies the time to live value (in msecs) of a positive cached credential |
protocol |
rquota_enabled |
boolean |
Specifies whether or not the remote quota feature is enabled. |
showmount_enabled |
boolean |
Specifies whether or not the showmount feature is enabled. |
state |
string |
Specifies the state of the NFS service on the SVM. The following values are supported: * online - NFS server is ready to accept client requests. * offline - NFS server is not ready to accept client requests. |
statistics |
Realtime performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol. |
svm |
transport |
vstorage_enabled |
boolean |
Specifies whether or not the VMware vstorage feature is enabled. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
