Retrieve NVMe subsystem controllers
GET /protocols/nvme/subsystem-controllers
Introduced In: 9.6
Retrieves NVMe subsystem controllers.
Related ONTAP commands
vserver nvme subsystem controller show
Learn more
node.name |
string |
query |
False |
Filter by node.name |
node.uuid |
string |
query |
False |
Filter by node.uuid |
subsystem.name |
string |
query |
False |
Filter by subsystem.name |
subsystem.uuid |
string |
query |
False |
Filter by subsystem.uuid |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
io_queue.count |
integer |
query |
False |
Filter by io_queue.count |
io_queue.depth |
integer |
query |
False |
Filter by io_queue.depth |
id |
string |
query |
False |
Filter by id |
admin_queue.depth |
integer |
query |
False |
Filter by admin_queue.depth |
interface.uuid |
string |
query |
False |
Filter by interface.uuid |
interface.transport_address |
string |
query |
False |
Filter by interface.transport_address |
interface.name |
string |
query |
False |
Filter by interface.name |
host.id |
string |
query |
False |
Filter by host.id |
host.transport_address |
string |
query |
False |
Filter by host.transport_address |
host.nqn |
string |
query |
False |
Filter by host.nqn |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[nvme_subsystem_controller] |
"next": {
"href": "/api/resourcelink"
"records": [
"admin_queue": {
"depth": 0
"host": {
"id": "b8546ca6097349e5b1558dc154fc073b",
"nqn": "nqn.2014-08.org.nvmexpress:uuid:c2846cb1-89d2-4020-a3b0-71ce907b4eef",
"transport_address": "nn-0x20000090fae00806:pn-0x10000090fae00806"
"id": "0040h",
"interface": {
"name": "lif1",
"transport_address": "nn-0x200400a0989a1c8d:pn-0x200500a0989a1c8d",
"uuid": "fa1c5941-2593-11e9-94c4-00a0989a1c8e"
"io_queue": {
"count": 0,
"depth": [
"integer"
"node": {
"name": "node1",
"subsystem": {
"name": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
admin_queue
depth |
integer |
The depth of the admin queue for the controller. |
host
Properties of the connected host.
id |
string |
The host identifier registered with the controller. |
nqn |
string |
The NVMe qualified name of the host. |
transport_address |
string |
The transport address of the host. |
interface
The logical interface through which the host is connected.
name |
string |
The name of the logical interface. |
transport_address |
string |
The transport address of the logical interface. |
uuid |
string |
The unique identifier of the logical interface. |
io_queue
Properties of the I/O queues available to the controller.
count |
integer |
The number of I/O queues available to the controller. |
depth |
array[integer] |
The depths of the I/O queues. |
node
_links |
name |
string |
uuid |
string |
subsystem
_links |
name |
string |
The name of the NVMe subsystem. |
uuid |
string |
The unique identifier of the NVMe subsystem. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
A Non-Volatile Memory Express (NVMe) subsystem controller represents a connection between a host and a storage solution.
An NVMe subsystem controller is identified by the NVMe subsystem UUID and the controller ID.
_links |
admin_queue |
host |
Properties of the connected host. |
id |
string |
The identifier of the subsystem controller. This field consists of 4 zero-filled hexadecimal digits followed by an 'h'. |
interface |
The logical interface through which the host is connected. |
io_queue |
Properties of the I/O queues available to the controller. |
node |
subsystem |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
