Retrieve an NVMe subsystem map
GET /protocols/nvme/subsystem-maps/{subsystem.uuid}/{namespace.uuid}
Introduced In: 9.6
Retrieves an NVMe subsystem map.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
anagrpid
Related ONTAP commands
vserver nvme subsystem map show
Learn more
subsystem.uuid  |
string  |
path  |
True  |
The unique identifier of the NVMe subsystem.  |
namespace.uuid  |
string  |
path  |
True  |
The unique identifier of the NVMe namespace.  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
anagrpid  |
string  |
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace. The format for an ANAGRPID is 8 hexadecimal digits (zero-filled) followed by a lower case "h". There is an added cost to retrieving this property's value. It is not populated for either a collection GET or an instance GET unless it is explicitly requested using the   |
namespace  |
The NVMe namespace to which the NVMe subsystem is mapped. Required in POST by supplying either the UUID, name, or both.  |
nsid  |
string  |
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace. The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h".  |
subsystem  |
The NVMe subsystem to which the NVMe namespace is mapped. Required in POST by supplying either   |
svm  |
      "href": "/api/resourcelink"
  "anagrpid": "00103050h",
  "namespace": {
    "name": "/vol/vol1/namespace1",
    "node": {
      "name": "node1",
  "nsid": "00000001h",
  "subsystem": {
    "name": "string",
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
72090019  |
The specified NVMe namespace is not mapped to the specified NVMe subsystem.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
node
_links  |
name  |
string  |
uuid  |
string  |
namespace
_links  |
name  |
string  |
The fully qualified path name of the NVMe namespace composed from the volume name, qtree name, and file name of the NVMe namespace. Valid in POST.  |
node  |
uuid  |
string  |
The unique identifier of the NVMe namespace. Valid in POST.  |
subsystem
The NVMe subsystem to which the NVMe namespace is mapped. Required in POST by supplying either subsystem.uuid, subsystem.name  or both.
_links  |
name  |
string  |
The name of the NVMe subsystem.  |
uuid  |
string  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
