Retrieve an NVMe subsystem host
GET /protocols/nvme/subsystems/{subsystem.uuid}/hosts/{nqn}
Introduced In: 9.6
Retrieves an NVMe subsystem host of an NVMe subsystem.
Related ONTAP commands
vserver nvme subsystem host show
Learn more
subsystem.uuid |
string |
path |
True |
The unique identifier of the NVMe subsystem. |
nqn |
string |
path |
True |
The NVMe qualified name (NQN) used to identify the NVMe subsystem host. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
io_queue |
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller. |
nqn |
string |
The NVMe qualified name (NQN) used to identify the NVMe storage target. Not allowed in POST when the |
subsystem |
The NVMe subsystem to which the NVMe host has been provisioned. |
"href": "/api/resourcelink"
"io_queue": {
"count": "4",
"depth": "32"
"nqn": "nqn.1992-01.example.com:string",
"subsystem": {
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
io_queue
count |
integer |
The number of I/O queue pairs. The default value is inherited from the owning NVMe subsystem. |
depth |
integer |
The I/O queue depth. The default value is inherited from the owning NVMe subsystem. |
subsystem
_links |
uuid |
string |
records
The NVMe host provisioned to access NVMe namespaces mapped to a subsystem.
_links |
io_queue |
nqn |
string |
subsystem |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
