Retrieve NVMe subsystem hosts
GET /protocols/nvme/subsystems/{subsystem.uuid}/hosts
Introduced In: 9.6
Retrieves the NVMe subsystem hosts of an NVMe subsystem.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
subsystem_maps.*
Related ONTAP commands
vserver nvme subsystem map show -
vserver nvme subsystem show
Learn more
subsystem.uuid |
string |
path |
True |
The unique identifier of the NVMe subsystem. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[nvme_subsystem_host] |
"next": {
"href": "/api/resourcelink"
"records": [
"io_queue": {
"count": "4",
"depth": "32"
"nqn": "nqn.1992-01.example.com:string",
"subsystem": {
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
io_queue
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller.
count |
integer |
The number of I/O queue pairs. The default value is inherited from the owning NVMe subsystem. |
depth |
integer |
The I/O queue depth. The default value is inherited from the owning NVMe subsystem. |
subsystem
The NVMe subsystem to which the NVMe host has been provisioned.
_links |
uuid |
string |
records
The NVMe host provisioned to access NVMe namespaces mapped to a subsystem.
_links |
io_queue |
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller. |
nqn |
string |
The NVMe qualified name (NQN) used to identify the NVMe storage target. Not allowed in POST when the |
subsystem |
The NVMe subsystem to which the NVMe host has been provisioned. |
nvme_subsystem_host
_links |
io_queue |
nqn |
string |
subsystem |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
