Retrieve S3 bucket configurations for an SVM
GET /protocols/s3/services/{svm.uuid}/buckets
Introduced In: 9.7
Retrieves the S3 bucket's configuration of an SVM. Note that in order to retrieve S3 bucket policy conditions, the 'fields' option should be set to '**'.
Related ONTAP commands
vserver object-store-server bucket show -
vserver object-store-server bucket policy statement show -
vserver object-store-server bucket policy-statement-condition show
policy.statements.conditions.source_ips |
string |
query |
False |
Filter by policy.statements.conditions.source_ips
policy.statements.conditions.prefixes |
string |
query |
False |
Filter by policy.statements.conditions.prefixes
policy.statements.conditions.operator |
string |
query |
False |
Filter by policy.statements.conditions.operator
policy.statements.conditions.max_keys |
integer |
query |
False |
Filter by policy.statements.conditions.max_keys
policy.statements.conditions.usernames |
string |
query |
False |
Filter by policy.statements.conditions.usernames
policy.statements.conditions.delimiters |
string |
query |
False |
Filter by policy.statements.conditions.delimiters
policy.statements.principals |
string |
query |
False |
Filter by policy.statements.principals
policy.statements.sid |
string |
query |
False |
Filter by policy.statements.sid
policy.statements.effect |
string |
query |
False |
Filter by policy.statements.effect
policy.statements.actions |
string |
query |
False |
Filter by policy.statements.actions
policy.statements.resources |
string |
query |
False |
Filter by policy.statements.resources
logical_used_size |
integer |
query |
False |
Filter by logical_used_size |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
encryption.enabled |
boolean |
query |
False |
Filter by encryption.enabled |
qos_policy.max_throughput_mbps |
integer |
query |
False |
Filter by qos_policy.max_throughput_mbps
qos_policy.max_throughput_iops |
integer |
query |
False |
Filter by qos_policy.max_throughput_iops
qos_policy.uuid |
string |
query |
False |
Filter by qos_policy.uuid
qos_policy.min_throughput_iops |
integer |
query |
False |
Filter by qos_policy.min_throughput_iops
qos_policy.min_throughput_mbps |
integer |
query |
False |
Filter by qos_policy.min_throughput_mbps
qos_policy.name |
string |
query |
False |
Filter by qos_policy.name
volume.uuid |
string |
query |
False |
Filter by volume.uuid |
volume.name |
string |
query |
False |
Filter by volume.name |
size |
integer |
query |
False |
Filter by size |
uuid |
string |
query |
False |
Filter by uuid |
name |
string |
query |
False |
Filter by name |
comment |
string |
query |
False |
Filter by comment |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[s3_bucket_svm] |
"next": {
"href": "/api/resourcelink"
"records": [
"comment": "S3 bucket.",
"logical_used_size": 0,
"name": "bucket1",
"policy": {
"statements": [
"actions": [
"GetObject",
"PutObject",
"DeleteObject",
"ListBucket"
"conditions": [
"delimiters": [
"max_keys": [
"1000"
"operator": "ip_address",
"prefixes": [
"pref"
"source_ips": [
"1.1.1.1",
"1.2.2.0/24"
"usernames": [
"user1"
"effect": "allow",
"principals": [
"user1",
"group/grp1"
"resources": [
"bucket1",
"bucket1/*"
"sid": "FullAccessToUser1"
"qos_policy": {
"max_throughput_iops": "10000",
"max_throughput_mbps": "500",
"min_throughput_iops": "2000",
"min_throughput_mbps": "500",
"name": "performance",
"size": "1677721600",
"svm": {
"name": "svm1",
"uuid": "414b29a1-3b26-11e9-bd58-0050568ea055",
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
_links
self |
aggregates
Aggregate
_links |
name |
string |
uuid |
string |
encryption
enabled |
boolean |
Specifies whether encryption is enabled on the bucket. By default, encryption is disabled on a bucket. |
s3_bucket_policy_condition
Information about policy conditions based on various condition operators and condition keys.
delimiters |
array[string] |
An array of delimiters that are compared with the delimiter value specified at the time of execution of an S3-based command, using the condition operator specified. |
max_keys |
array[integer] |
An array of maximum keys that are allowed or denied to be retrieved using an S3 list operation, based on the condition operator specified. |
operator |
string |
Condition operator that is applied to the specified condition key. |
prefixes |
array[string] |
An array of prefixes that are compared with the input prefix value specified at the time of execution of an S3-based command, using the condition operator specified. |
source_ips |
array[string] |
An array of IP address ranges that are compared with the IP address of a source command at the time of execution of an S3-based command, using the condition operator specified. |
usernames |
array[string] |
An array of usernames that a current user in the context is evaluated against using the condition operators. |
s3_bucket_policy_statement
Specifies information about a single access permission.
actions |
array[string] |
conditions |
array[s3_bucket_policy_condition] |
Specifies bucket policy conditions. |
effect |
string |
Specifies whether access is allowed or denied when a user requests the specific action. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access. |
principals |
array[string] |
resources |
array[string] |
sid |
string |
Specifies the statement identifier used to differentiate between statements. |
policy
A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies get evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied.
statements |
array[s3_bucket_policy_statement] |
Specifies bucket access policy statement. |
qos_policy
Specifes "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops". Specifes "min_throughput_iops" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a bucket is not supported if its containing volume or SVM already has a QoS policy attached.
_links |
integer |
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
integer |
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
integer |
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. |
integer |
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
name |
string |
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH. |
uuid |
string |
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
Specifies the FlexGroup volume name and UUID where the bucket is hosted.
_links |
name |
string |
The name of the volume. |
uuid |
string |
s3_bucket_svm
A bucket is a container of objects. Each bucket defines an object namespace. S3 requests specify objects using a bucket-name and object-name pair. An object resides within a bucket.
comment |
string |
Can contain any additional information about the bucket being created or modified. |
encryption |
logical_used_size |
integer |
Specifies the bucket logical used size up to this point. |
name |
string |
Specifies the name of the bucket. Bucket name is a string that can only contain the following combination of ASCII-range alphanumeric characters 0-9, a-z, ".", and "-". |
policy |
A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies get evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied. |
qos_policy |
Specifes "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops". Specifes "min_throughput_iops" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a bucket is not supported if its containing volume or SVM already has a QoS policy attached. |
size |
integer |
Specifies the bucket size in bytes; ranges from 80MB to 64TB. |
svm |
uuid |
string |
Specifies the unique identifier of the bucket. |
volume |
Specifies the FlexGroup volume name and UUID where the bucket is hosted. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
