Retrieve S3 policies in SVM configuration
GET /protocols/s3/services/{svm.uuid}/policies
Introduced In: 9.8
Retrieves the S3 policies SVM configuration.
Related ONTAP commands
vserver object-store-server policy show
name |
string |
query |
False |
Filter by name |
statements.sid |
string |
query |
False |
Filter by statements.sid |
statements.effect |
string |
query |
False |
Filter by statements.effect |
statements.index |
integer |
query |
False |
Filter by statements.index |
statements.resources |
string |
query |
False |
Filter by statements.resources |
statements.actions |
string |
query |
False |
Filter by statements.actions |
comment |
string |
query |
False |
Filter by comment |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
read-only |
boolean |
query |
False |
Filter by read-only |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[s3_policy] |
"next": {
"href": "/api/resourcelink"
"records": [
"comment": "S3 policy.",
"name": "Policy1",
"statements": [
"actions": [
"effect": "allow",
"index": 0,
"resources": [
"bucket1",
"bucket1/*"
"sid": "FullAccessToBucket1"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
s3_policy_statement
Specifies information about a single access policy statement.
actions |
array[string] |
For each resource, S3 supports a set of operations. The resource operations allowed or denied are identified by an action list:
effect |
string |
Specifies whether access is allowed or denied. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access. |
index |
integer |
Specifies a unique statement index used to identify a particular statement. This parameter should not be specified in the POST method. A statement index is automatically generated and is retrieved using the GET method. |
resources |
array[string] |
sid |
string |
Specifies the statement identifier which contains additional information about the statement. |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
s3_policy
An S3 policy is an object. It defines resource (bucket, folder or object) permissions. These policies get evaluated when an object store user user makes a request. Permissions in the policies determine whether the request is allowed or denied.
comment |
string |
Can contain any additional information about the S3 policy. |
name |
string |
Specifies the name of the policy. A policy name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
read-only |
boolean |
Specifies whether or not the s3 policy is read only. This parameter should not be specified in the POST method. |
statements |
array[s3_policy_statement] |
Specifies the policy statements. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
