Retrieve the S3 user configuration for an SVM
GET /protocols/s3/services/{svm.uuid}/users/{name}
Introduced In: 9.7
Retrieves the S3 user configuration of an SVM.
Related ONTAP commands
vserver object-store-server user show
Learn more
name  |
string  |
path  |
True  |
User name  |
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
access_key  |
string  |
Specifies the access key for the user.  |
comment  |
string  |
Can contain any additional information about the user being created or modified.  |
name  |
string  |
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".  |
svm  |
  "access_key": "Pz3SB54G2B_6dsXQPrA5HrTPcf478qoAW6_Xx6qyqZ948AgZ_7YfCf_9nO87YoZmskxx3cq41U2JAH2M3_fs321B4rkzS3a_oC5_8u7D8j_45N8OsBCBPWGD_1d_ccfq",
  "comment": "S3 user",
  "name": "user-1",
  "svm": {
        "href": "/api/resourcelink"
    "name": "svm1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
