Retrieve an initiator
GET /protocols/san/igroups/{igroup.uuid}/initiators/{name}
Introduced In: 9.6
Retrieves an initiator of an initiator group.
Related ONTAP commands
lun igroup show
Learn more
igroup.uuid |
string |
path |
True |
The unique identifier of the initiator group. |
name |
string |
path |
True |
Initiator name |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
igroup |
The initiator group in which the initiator is found. Note that this does not mean that the initiator cannot also be found in other initiator groups. |
name |
string |
The FC WWPN, iSCSI IQN, or iSCSI EUI that identifies the host initiator. Valid in POST only and not allowed when the An FC WWPN consist of 16 hexadecimal digits grouped as 8 pairs separated by colons. The format for an iSCSI IQN is iqn.yyyy-mm.reverse_domain_name:any. The iSCSI EUI format consists of the eui. prefix followed by 16 hexadecimal characters. |
"href": "/api/resourcelink"
"igroup": {
"name": "iqn.1998-01.com.corp.iscsi:name1"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
4 |
The initiator is not a member of the initiator group. |
5374852 |
The initiator group specified in the URI does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
igroup
_links |
uuid |
string |
records
_links |
igroup |
name |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
