Retrieve specific iSCSI credentials
GET /protocols/san/iscsi/credentials/{svm.uuid}/{initiator}
Introduced In: 9.6
Retrieves specified iSCSI credentials.
Related ONTAP commands
vserver iscsi security show
Learn more
svm.uuid |
string |
path |
True |
The unique identifier of an SVM. |
initiator |
string |
path |
True |
The iSCSI initiator of the credentials object. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
authentication_type |
string |
The iSCSI authentication type. Required in POST and optional in PATCH. |
chap |
Challenge-Handshake Authentication Protocol (CHAP) credentials. |
initiator |
string |
The iSCSI initiator to which the credentials apply. Required in POST. |
initiator_address |
Initiator address ranges. |
svm |
"href": "/api/resourcelink"
"authentication_type": "string",
"chap": {
"inbound": {
"user": "string"
"outbound": {
"user": "string"
"initiator": "iqn.1998-01.com.corp.iscsi:name1",
"initiator_address": {
"masks": [
"address": "10.10.10.7",
"family": "string",
"netmask": "24"
"ranges": [
"end": "10.10.10.7",
"family": "string",
"start": "10.10.10.7"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
inbound
Inbound CHAP credentials.
user |
string |
The inbound CHAP user name. Optional in POST and PATCH. |
outbound
Output CHAP credentials.
user |
string |
The outbound CHAP user name. Optional in POST and PATCH. |
chap
inbound |
Inbound CHAP credentials. |
outbound |
Output CHAP credentials. |
ip_info
IP information
address |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length. |
ip_address_range
IP address range
end |
string |
family |
string |
IPv4 or IPv6 |
start |
string |
initiator_address
masks |
array[ip_info] |
ranges |
array[ip_address_range] |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
