Retrieve a LUN map
GET /protocols/san/lun-maps/{lun.uuid}/{igroup.uuid}
Introduced In: 9.6
Retrieves a LUN map.
Related ONTAP commands
lun mapping show
Learn more
lun.uuid  |
string  |
path  |
True  |
The unique identifier of the LUN.  |
igroup.uuid  |
string  |
path  |
True  |
The unique identifier of the igroup.  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
igroup  |
The initiator group to which the LUN is mapped. Required in POST by supplying either the   |
logical_unit_number  |
integer  |
The logical unit number assigned to the LUN when mapped to the specified initiator group. The number is used to identify the LUN to initiators in the initiator group when communicating through Fibre Channel Protocol or iSCSI. Optional in POST; if no value is provided, ONTAP assigns the lowest available value.
lun  |
The LUN to which the initiator group is mapped. Required in POST by supplying either the   |
svm  |
      "href": "/api/resourcelink"
  "igroup": {
    "initiators": [
      "iqn.1998-01.com.corp.iscsi:name1"
    "name": "igroup1",
    "os_type": "string",
    "protocol": "string",
    "uuid": "1ad8544d-8cd1-91e0-9e1c-723478563412"
  "logical_unit_number": "1",
  "lun": {
    "name": "/vol/volume1/qtree1/lun1",
    "node": {
      "name": "node1",
      "uuid": "1cf8aa42-8cd1-12e0-a11c-423468563412"
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374852  |
The initiator group was not found.  |
5374875  |
The LUN was not found.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
igroup
The initiator group to which the LUN is mapped. Required in POST by supplying either the igroup.uuid, igroup.name, or both.
_links  |
initiators  |
array[string]  |
The initiators that are members of the initiator group.  |
name  |
string  |
The name of the initiator group. Valid in POST.  |
os_type  |
string  |
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system.  |
protocol  |
string  |
The protocols supported by the initiator group. This restricts the type of initiators that can be added to the initiator group.  |
uuid  |
string  |
The unique identifier of the initiator group. Valid in POST.  |
node
The LUN node.
_links  |
name  |
string  |
The name the LUN's node.  |
uuid  |
string  |
The unique identifier of the LUN node.  |
lun
The LUN to which the initiator group is mapped. Required in POST by supplying either the lun.uuid, lun.name, or both.
_links  |
name  |
string  |
The fully qualified path name of the LUN composed of a "/vol" prefix, the volume name, the (optional) qtree name, and file name of the LUN. Valid in POST.  |
node  |
The LUN node.  |
uuid  |
string  |
The unique identifier of the LUN. Valid in POST.  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
