Retrieve LUN maps
GET /protocols/san/lun-maps
Introduced In: 9.6
Retrieves LUN maps.
Related ONTAP commands
lun mapping show
lun.node.name |
string |
query |
False |
Filter by lun.node.name |
lun.node.uuid |
string |
query |
False |
Filter by lun.node.uuid |
lun.name |
string |
query |
False |
Filter by lun.name |
lun.uuid |
string |
query |
False |
Filter by lun.uuid |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
igroup.protocol |
string |
query |
False |
Filter by igroup.protocol |
igroup.name |
string |
query |
False |
Filter by igroup.name |
igroup.uuid |
string |
query |
False |
Filter by igroup.uuid |
igroup.os_type |
string |
query |
False |
Filter by igroup.os_type |
igroup.initiators |
string |
query |
False |
Filter by igroup.initiators |
logical_unit_number |
integer |
query |
False |
Filter by logical_unit_number |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[lun_map] |
"next": {
"href": "/api/resourcelink"
"records": [
"igroup": {
"initiators": [
"iqn.1998-01.com.corp.iscsi:name1"
"name": "igroup1",
"os_type": "string",
"protocol": "string",
"uuid": "1ad8544d-8cd1-91e0-9e1c-723478563412"
"logical_unit_number": "1",
"lun": {
"name": "/vol/volume1/qtree1/lun1",
"node": {
"name": "node1",
"uuid": "1cf8aa42-8cd1-12e0-a11c-423468563412"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
igroup
The initiator group to which the LUN is mapped. Required in POST by supplying either the igroup.uuid, igroup.name, or both.
_links |
initiators |
array[string] |
The initiators that are members of the initiator group. |
name |
string |
The name of the initiator group. Valid in POST. |
os_type |
string |
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system. |
protocol |
string |
The protocols supported by the initiator group. This restricts the type of initiators that can be added to the initiator group. |
uuid |
string |
The unique identifier of the initiator group. Valid in POST. |
node
The LUN node.
_links |
name |
string |
The name the LUN's node. |
uuid |
string |
The unique identifier of the LUN node. |
lun
The LUN to which the initiator group is mapped. Required in POST by supplying either the lun.uuid, lun.name, or both.
_links |
name |
string |
The fully qualified path name of the LUN composed of a "/vol" prefix, the volume name, the (optional) qtree name, and file name of the LUN. Valid in POST. |
node |
The LUN node. |
uuid |
string |
The unique identifier of the LUN. Valid in POST. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
lun_map
A LUN map is an association between a LUN and an initiator group. When a LUN is mapped to an initiator group, the initiator group's initiators are granted access to the LUN. The relationship between a LUN and an initiator group is many LUNs to many initiator groups.
_links |
igroup |
The initiator group to which the LUN is mapped. Required in POST by supplying either the |
integer |
The logical unit number assigned to the LUN when mapped to the specified initiator group. The number is used to identify the LUN to initiators in the initiator group when communicating through Fibre Channel Protocol or iSCSI. Optional in POST; if no value is provided, ONTAP assigns the lowest available value.
lun |
The LUN to which the initiator group is mapped. Required in POST by supplying either the |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
