REST API reference
Retrieve the Vscan configuration
GET /protocols/vscan
Introduced In: 9.6
Retrieves the Vscan configuration. This includes scanner-pools, On-Access policies, On-Demand policies, and information about whether a Vscan is enabled or disabled on an SVM.
Important notes:
  • You can enable only one Vscan configuration at a time for an SVM.
  • You can only query using svm.uuid or svm.name.
  • vserver vscan show
  • vserver vscan scanner-pool show
  • vserver vscan scanner-pool servers show
  • vserver vscan scanner-pool privileged-users show
  • vserver vscan scanner-pool show-active
  • vserver vscan on-access-policy show
  • vserver vscan on-access-policy file-ext-to-exclude show
  • vserver vscan on-access-policy file-ext-to-include show
  • vserver vscan on-access-policy paths-to-exclude show
  • vserver vscan on-demand-task show
on_access_policies.name
string
query
False
Filter by on_access_policies.name
on_access_policies.scope.only_execute_access
boolean
query
False
Filter by on_access_policies.scope.only_execute_access
on_access_policies.scope.include_extensions
string
query
False
Filter by on_access_policies.scope.include_extensions
on_access_policies.scope.exclude_extensions
string
query
False
Filter by on_access_policies.scope.exclude_extensions
on_access_policies.scope.scan_readonly_volumes
boolean
query
False
Filter by on_access_policies.scope.scan_readonly_volumes
on_access_policies.scope.exclude_paths
string
query
False
Filter by on_access_policies.scope.exclude_paths
on_access_policies.scope.max_file_size
integer
query
False
Filter by on_access_policies.scope.max_file_size
on_access_policies.scope.scan_without_extension
boolean
query
False
Filter by on_access_policies.scope.scan_without_extension
on_access_policies.mandatory
boolean
query
False
Filter by on_access_policies.mandatory
on_access_policies.enabled
boolean
query
False
Filter by on_access_policies.enabled
enabled
boolean
query
False
Filter by enabled
on_demand_policies.scan_paths
string
query
False
Filter by on_demand_policies.scan_paths
on_demand_policies.log_path
string
query
False
Filter by on_demand_policies.log_path
on_demand_policies.scope.include_extensions
string
query
False
Filter by on_demand_policies.scope.include_extensions
on_demand_policies.scope.scan_without_extension
boolean
query
False
Filter by on_demand_policies.scope.scan_without_extension
on_demand_policies.scope.max_file_size
integer
query
False
Filter by on_demand_policies.scope.max_file_size
on_demand_policies.scope.exclude_paths
string
query
False
Filter by on_demand_policies.scope.exclude_paths
on_demand_policies.scope.exclude_extensions
string
query
False
Filter by on_demand_policies.scope.exclude_extensions
on_demand_policies.schedule.name
string
query
False
Filter by on_demand_policies.schedule.name
on_demand_policies.schedule.uuid
string
query
False
Filter by on_demand_policies.schedule.uuid
on_demand_policies.name
string
query
False
Filter by on_demand_policies.name
scanner_pools.cluster.name
string
query
False
Filter by scanner_pools.cluster.name
scanner_pools.cluster.uuid
string
query
False
Filter by scanner_pools.cluster.uuid
scanner_pools.role
string
query
False
Filter by scanner_pools.role
scanner_pools.privileged_users
string
query
False
Filter by scanner_pools.privileged_users
scanner_pools.name
string
query
False
Filter by scanner_pools.name
scanner_pools.servers
string
query
False
Filter by scanner_pools.servers
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[vscan]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "on_access_policies": [
          "name": "on-access-test",
          "scope": {
            "exclude_extensions": [
              "mp*",
              "txt"
            "exclude_paths": [
              "\\dir1\\dir2\\name",
              "\\vol\\a b",
              "\\vol\\a,b\\"
            "include_extensions": [
              "mp*",
              "txt"
            "max_file_size": "2147483648"
      "on_demand_policies": [
          "log_path": "/vol0/report_dir",
          "name": "task-1",
          "scan_paths": [
            "/vol1/",
            "/vol2/cifs/"
          "schedule": {
            "name": "weekly",
          "scope": {
              "mp3",
              "mp4"
            "exclude_paths": [
              "/vol1/cold-files/",
              "/vol1/cifs/names"
              "vmdk",
              "mp*"
            "max_file_size": "10737418240"
      "scanner_pools": [
          "cluster": {
            "name": "cluster1",
          "name": "scanner-1",
          "privileged_users": [
            "cifs\\u1",
            "cifs\\u2"
          "role": "string",
          "servers": [
            "1.1.1.1",
            "10.72.204.27",
            "vmwin204-27.fsct.nb"
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
scope
exclude_extensions
array[string]
List of file extensions for which scanning is not performed.
exclude_paths
array[string]
List of file paths for which scanning must not be performed.
include_extensions
array[string]
List of file extensions to be scanned.
max_file_size
integer
Maximum file size, in bytes, allowed for scanning.
only_execute_access
boolean
Scan only files opened with execute-access.
boolean
Specifies whether or not read-only volume can be scanned.
boolean
Specifies whether or not files without any extension can be scanned.
vscan_on_access
An On-Access policy that defines the scope of an On-Access scan. Use On-Access scanning to check for viruses when clients open, read, rename, or close files over CIFS. By default, ONTAP creates an On-Access policy named "default_CIFS" and enables it for all the SVMs in a cluster.
enabled
boolean
Status of the On-Access Vscan policy
mandatory
boolean
Specifies if scanning is mandatory. File access is denied if there are no external virus-scanning servers available for virus scanning.
name
string
On-Access policy ame
scope
scope
schedule
Schedule of the task.
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
scope
exclude_extensions
array[string]
exclude_paths
array[string]
include_extensions
array[string]
max_file_size
integer
boolean
vscan_on_demand
Use On-Demand scanning to check files for viruses on a schedule. An On-Demand policy defines the scope of an On-Demand scan.
log_path
string
The path from the Vserver root where the task report is created.
name
string
On-Demand task name
scan_paths
array[string]
List of paths that need to be scanned.
schedule
schedule
scope
scope
cluster_reference
_links
_links
name
string
uuid
string
vscan_scanner_pool
Scanner pool is a set of attributes which are used to validate and manage connections between clustered ONTAP and external virus-scanning server, or "Vscan server".
cluster
cluster_reference
name
string
Specifies the name of the scanner pool. Scanner pool name can be up to 256 characters long and is a string that can only contain any combination of ASCII-range alphanumeric characters a-z, A-Z, 0-9), "_", "-" and ".".
privileged_users
array[string]
Specifies a list of privileged users. A valid form of privileged user-name is "domain-name\user-name". Privileged user-names are stored and treated as case-insensitive strings. Virus scanners must use one of the registered privileged users for connecting to clustered Data ONTAP for exchanging virus-scanning protocol messages and to access file for scanning, remedying and quarantining operations.
  • example: ["cifs\u1", "cifs\u2"]
  • Introduced in: 9.6
  • x-omitemtpy: true
role
string
Specifies the role of the scanner pool. The possible values are:
  • primary - Always active.
  • secondary - Active only when none of the primary external virus-scanning servers are connected.
  • idle - Always inactive.
servers
array[string]
Specifies a list of IP addresses or FQDN for each Vscan server host names which are allowed to connect to clustered ONTAP.
  • example: ["1.1.1.1", "10.72.204.27", "vmwin204-27.fsct.nb"]
  • x-omitemtpy: true
svm
_links
_links
name
string
The name of the SVM.
uuid
string
vscan
Vscan can be used to protect data from being compromised by viruses or other malicious code. This combines best-in-class third-party antivirus software with ONTAP features that give you the flexibility you need to control which files get scanned and when. Storage systems offload scanning operations to external servers hosting antivirus software from thirdparty vendors. An Antivirus Connector on the external server handles communications between the storage system and the antivirus software.
_links
_links
cache_clear
boolean
Discards the cached information of the files that have been successfully scanned. Once the cache is cleared, files are scanned again when they are accessed. PATCH only
enabled
boolean
Specifies whether or not Vscan is enabled on the SVM.
on_access_policies
array[vscan_on_access]
on_demand_policies
array[vscan_on_demand]
scanner_pools
array[vscan_scanner_pool]
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
